September 5, 2018, 13:43 |
How to build a variable solution domain
Wenming Yang
Rep Power: 7 |
Dear all,
I need to solve a problem whose physical domain is changing with time. My thought is that the domain is build and mesh at each run time and using parameterizing modelling in the blockMeshDict. Following this idea, I want to include the blockMesh.C in the main routine, but failed after several times of try. Does anyone has better ideas? Thanks a lot. |
September 6, 2018, 08:52 |
Thomas Oliveira
Rep Power: 12 |
Dear Yang,
See if this presentation by Hrvoje Jasak and Henrik Rusche can help you and give you keywords for further research. Kind regards, Thomas |
September 6, 2018, 08:55 |
Michael Alletto
Rep Power: 15 |
the dynamic mesh of openfoam or the overset Mesh available in openfoam.com and openfaom extend may help you
September 6, 2018, 09:59 |
Wenming Yang
Rep Power: 7 |
Dear Oliveira and Alletto,
Thank you for your advices. I will have a try. Best, |
variable solution domain |
Discrete vs Continuous Adjoint solution variable: Scaling/normalization issue? | asitav | SU2 | 2 | November 21, 2018 19:11 |
Can CFX model periodic heat transfer problem | Ethan_Sparkle | CFX | 41 | June 14, 2017 07:22 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Different diffusivity for additional variable in Fluid and porous domain | ftab | CFX | 4 | June 27, 2012 13:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
