VoF Volume detection
Like Tree1Likes
  • 1 Post By maHein
Old   November 10, 2018, 10:08
Default VoF Volume detection
maHein is on a distinguished road
I am implementing a solver for the conversion of VoF droplets to Lagrangian particles. Therefore I need to identify all enclosed VoF droplets in order to convert them to particles with equal size / mass / momentum. Beginning with a certain cell, I recursively iterate over every neighbouring cell until I find no more liquid cell (marker_ functions as a variable to distinguish between gas and liquid).
The recursive function looks like the following:
// cellI - label of starting cell
// volID - ID for the resulting enclosed VoF droplet
// marker_ - volScalarField to check for gas (= 0) and liquid (= 1)
// volumeID_ - volScalarField, where connecting liquid cells have the same ID
void checkRecursive(label cellI, const scalar& volID)
    // get neighbours of cellI
    const labelList& neighbours = mesh_.cellCells()[cellI];
    // loop over all neighbouring cells of cellI
    forAll(neighbours,i)
        // neighbour cell ID
        label neighbourI = neighbours[i];
        // check if neighbour cell is liquid
        if (marker_[neighbourI] > 0.5)
            // set volume ID
	    volumeID_[neighbourI] = volID;
            // reset marker to avoid infinite loop
	    marker_[neighbourI] = 0.0;
            // repeat check for all neighbours recursively
            checkConnection(neighbourI, volID);
This function works up to a certain point (after checking thousands and thousands of cells on large meshes) when suddenly a segmentation fault occurs. Although, up to this point all cell and neighboring labels look reasonable. It looks like OpenFOAM tries to access data which is not available / outside of the stored field ranges. How could that be possible? I am just looking for the neighbors of a given cell?
Does someone has any advise to get rid of that error?
Regards
Martin
amolrajan likes this.
maHein is offline   Reply With Quote
Old   November 13, 2018, 06:19
Rodrigo
guin is on a distinguished road
            // set volume ID
Regards
Martin
Quick question: does it crash when reaching a non-processor boundary?
guin is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 07:09
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Fluent VOF Volume of Fluid Realistic Solution Problem wormik FLUENT 3 June 21, 2009 07:04
