explain implications of this comment
Old   February 4, 2019, 23:27
Unhappy explain implications of this comment
fedvasu is on a distinguished road
Hi Forum,
I am porting my code from OF-6 to OF-dev (latest)
what are the implications of of this commits
https://github.com/OpenFOAM/OpenFOAM...c39005b2091117
mesh.solver is no longer present, then how can i specify that for this equation this particular solver settings, I have two separate pressure equations and I have two different settings in fvSolution but for second equation is constructed using a copy of the original pressure how can I tell OF to use the settings for the other equation?
fedvasu is offline   Reply With Quote
Old   February 5, 2019, 12:58
Andrew Somorjai
massive_turbulence is on a distinguished road
Originally Posted by fedvasu View Post
Hi Forum,
It would help if you posted the pressure equations, the fvSolutions and whatever is necessary to see the problem.
massive_turbulence is offline   Reply With Quote
Old   February 6, 2019, 18:19
Main pressure equation
// Pressure corrector
    fvScalarMatrix pEqn
        fvm::ddt(psi, p)
        + fvc::div(phiHbyA)
        - fvm::laplacian(rhorAUf, p)
        fvOptions(psi, p, rho.name())
    fvOptions.constrain(pEqn);
    pEqn.solve(mesh.solver(p.select(pimple.finalInnerIter())));
    if (pimple.finalNonOrthogonalIter())
        phi = phiHbyA + pEqn.flux();
other pressure equation, variable named pressure
fvScalarMatrix pressureEqn
	            fvm::laplacian(rhorAUf, pressure)
	            - fvm::ddt(psi, pressure)
                Rm_
                //Rm_TA
            pressureEqn.setReference(pressureRefCell, pressureRefValue);
            pressureEqn.solve(mesh_.solver("pressure")); //how would I give this info?
            if (nonOrth == nNonOrthCorr)
		        phiFVstage3 =  -pressureEqn.flux();
Old   February 6, 2019, 19:09
Andrew Somorjai
    fvScalarMatrix pEqn
        fvm::ddt(psi, p)
        + fvc::div(phiHbyA)
                Rm_
                //Rm_TA
What would be wrong with doing this in the second one
                fvOptions(???)
fvOptions.constrain(pressureEqn);
Is it because that would only check the same object file as before in the 1st or because you would overwrite variables needed from the 1st call?
Old   March 21, 2019, 23:44
                fvOptions(???)
My RHS is not 0 or given through fvOptions.
Anyway it seems, this is a API simplification it seems,
pEqn.solve() will find apply the fvSolution settings for the appropriate variable automatically.
This hasn't affected me at all. (adversley or otherwise).
I would mark this thread solved, if anyone with intimate knowledge of the API can definitively answer this.
development, new code, openfoam, pressure
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 09:04
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 03:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
