Weird Problem while compiling new library
Like Tree1Likes
  • 1 Post By ashish.vinayak
Old   February 22, 2019, 07:38
Default Weird Problem while compiling new library
Ashish Vinayak
ashish.vinayak is on a distinguished road
Hello everyone,
I am trying to compile $FOAM_SRC/transportModels separately since I want to rewrite the $FOAM_SRC/transportModels/interfaceProperties library. I created $WM_PROJECT_USER_DIR/src folder and copied $FOAM_SRC/transportModels to it.
The library seems to compile correctly and is present in $FOAM_USER_LIBBIN. I then copied interFOAM to $WM_PROJECT_USER_DIR/applications to compile the solver based on this "new" libraries. Changed all the required data in Make/options as well. However, when I try to compile interFOAM using these "new" libraries, I get undefined references. I have attached the error report for the solver compilation. Has someone faced this or a similar kind of problem?
I can provide all the information required, if someone is able to help me !
PS. OpenFOAM-5.x
ashish.vinayak is offline   Reply With Quote
Old   February 22, 2019, 08:37
Ashish Vinayak
Okay, I seem to have solved the problem myself. Turns out that wmake does not return any error if it does not find the correct file in the linking process.
For future reference:
ldd libname.so
can be used to find which files are not linked correctly and then the correct links can be established.
Daniel_Khazaei likes this.
Old   March 14, 2019, 09:46
dviam is on a distinguished road
ldd libname.so
Can you expound on the steps you took to get the linking done properly? I am having a similar issue where my new library compiles properly but when I try to compile the solver using wmake, I am getting undefined references errors. To my knowledge, the Make options file is correctly pointing to the new library.
dviam is offline   Reply With Quote
Old   March 15, 2019, 10:39
Ashish Vinayak
I would suggest you look if all the supported libraries are linked properly. Use
>> ldd libname.so
where libname is the library in the USER OpenFOAM directory (OpenFOAM/usrname/platforms/linuxXYZOpt/libs/libname.so) and post the output so that I could help you debug.
library solver linking
Problem in compiling fluent UDF lunched from MATLAB cfdman10 Fluent UDF and Scheme Programming 16 December 5, 2019 05:32
Problem linking library AlmostSurelyRob OpenFOAM Programming & Development 19 March 1, 2017 09:59
Compiling library changes Stephen Waite OpenFOAM Programming & Development 4 August 26, 2016 19:41
Compiling library and linking it to a solver criolla OpenFOAM 2 July 27, 2016 03:13
Problem compiling custom boundary condition as a library leroyv OpenFOAM Programming & Development 2 January 21, 2014 10:44
