How to implement a given bubble size distribution in twoPhaseEulerFoam? |
May 25, 2022, 10:32 |
Huan Zhang
Rep Power: 5 |
Dear Foamers,
I am simulating air jet into water using twoPhaseEulerFoam, and I want to know how to implement a given bubble size distribution? For example, the bubble size varies like a Gaussian curve at any location of the computational domain. Do I need to modify the diameter model in phaseProperties? Is there anyway to achieve this? I am looking forward to any suggestions! |
May 25, 2022, 13:02 |
Federico Zabaleta
Rep Power: 10 |
Well... in twoPhaseEulerFoam the coupling between phases comes from the interaction forces. If you have bubbles in some liquid, the drag depends on the bubble diameter. You can either use one phase for each bubble diameter, or you can define an equivalent bubble radius based on you bubble size distribution.
May 25, 2022, 19:06 |
#3 | |
Huan Zhang
Rep Power: 5 |
Thanks for your suggestions. What I want to do is to define the bubble diameters using the size distribution as shown in the attachment. Of course I can use an equivalent bubble size of 1.5 mm, but is there anyway to use this distribution profile? Best, Jasper |
May 25, 2022, 19:11 |
Federico Zabaleta
Rep Power: 10 |
If your question is if there is any place where you put that curve and then the code considers that distribution, the answer is no.
To the best of my knowledge, you should do some modifications to the source code to get a drag model that considers a bubble distribution. |
Error in enabling the python wrapper | Jinn | SU2 Installation | 2 | April 23, 2022 13:52 |
Size distribution for twoPhaseEulerFoam | cshsgy | OpenFOAM Pre-Processing | 0 | October 21, 2017 05:10 |
UDF for Droplet size distribution | Jufri | Fluent Multiphase | 1 | May 18, 2015 07:27 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
how to make particle size distribution | adma | CFX | 0 | January 10, 2006 15:57 |
