Porting viscoelasticFluidFoam to Official OpenFOAM
Old   March 1, 2019, 17:30
Default Porting viscoelasticFluidFoam to Official OpenFOAM
xuegy is on a distinguished road
Hello everyone,
I'm trying to move viscoelasticFluidFoam and its libraries from foam-extend-4.1 and compile it in official v1812. Foam-extend now has tons of compatibility issues and I need to use the official version for my second stage simulation so I have to port it.
After fixing so many syntax issues, I'm trapped by a weird error:
In /src/viscoelastic/viscoelasticLaws/multiMode/multiMode.C
Foam::multiMode::divTau(volVectorField& U) const
    tmp<fvVectorMatrix> divMatrix = models_[0].divTau(U);
    for (label i = 1; i < models_.size(); i++)
        divMatrix() += models_[i].divTau(U);
    return divMatrix;
The compiler gives the following error:
viscoelasticLaws/multiMode/multiMode.C: In member function ‘virtual Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::multiMode::divTau(Foam::volVectorField&) const’:
viscoelasticLaws/multiMode/multiMode.C:98:43: error: passing ‘const Foam::fvMatrix<Foam::Vector<double> >’ as ‘this’ argument discards qualifiers [-fpermissive]
I googled, and people say that the solution is adding a 'const' to the function. However, there's already a 'const'. I'm totally lost. How to fix this issue?
Thanks!
xuegy is offline   Reply With Quote
Old   March 2, 2019, 01:52
I have successfully compiled the solver by removing multiMode model. However, I still want to fix this issue and maybe upload the revised compatible solver to GitHub.
Old   May 26, 2022, 03:29
Xiaobo YAO
hdotyao is on a distinguished road
hi,
I am also compiling viscoelasticFluidFoam to official OpenFOAM. And I am facing the same issue. I need this multiMode so I don't want to delete it. Have you solved it?
Best
hdotyao is offline   Reply With Quote
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
openfoam official repository for unsupported code sail OpenFOAM 8 December 19, 2012 08:28
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
