Compilation error in OpenFOAM in WSL
Old   July 15, 2019, 10:27
Default Compilation error in OpenFOAM in WSL
Pablo Alarcón
palarcon is on a distinguished road
Good afternoon everybody
Today something strange happened to me. I tried to launch blockMesh in a simple mesh that uses #calc to compute some coordinates and I got the error showed below. The strange part is that I was able to compile the exact same mesh until this morning, without any modifications. Also, I'm able to use blockMesh in a cluster, namely, the problem only arises in my personal laptop.
If any of you has a clue related to this problem I will be enormously grateful.
Thank you in advance
First error:
/opt/openfoam5/src/OpenFOAM/lnInclude/scalar.H:44:15: error: ‘Scalar’ was not declared in this scope
 class pTraits<Scalar>
/opt/openfoam5/src/OpenFOAM/lnInclude/scalar.H:44:21: error: template argument 1 is invalid
Last error:
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_9432dc904ef3d3e0c82b64892ec6b07a02820e92/platforms/linux64GccDPInt32Opt/lib/libcodeStream_9432dc904ef3d3e0c82b64892ec6b07a02820e92.so"
file: /mnt/c/Users/pablo/OneDrive/Recherche/Code/OpenFOAM/pablo-5.0/run/plate/system/blockMeshDict from line 17 to line 23.
    From function static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
    in file db/dictionary/functionEntries/codeStream/codeStream.C at line 218.
He blockMeshDict file is the following
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
xmax 50;
ymax 50;
delta 5;	// elements per milimeter
e 2;		// channel thickness
y1 5;		// distance from the border
y2 #calc "$y1 + $e";
y3 #calc "$ymax - $y1 - $e";
y4 #calc "$ymax - $y1";
ycell1 #calc "$y1*$delta";
ycell2 #calc "$e*$delta";
ycell3 #calc "($ymax - 2*$y2)*$delta";
xcell #calc "$xmax*$delta";
vertices
	(0     0     0)	// P0
	($xmax 0     0)	// P1
	($xmax $y1   0)	// P2
	($xmax $y2   0)	// P3
	($xmax $y3   0)	// P4
	($xmax $y4   0)	// P5
	($xmax $ymax 0)	// P6
	(0     $ymax 0)	// P7
	(0     $y4   0)	// P8
	(0     $y3   0)	// P9
	(0     $y2   0)	// P10
	(0     $y1   0)	// P11
	(0     0     0.1)	// P12
	($xmax 0     0.1)	// P13
	($xmax $y1   0.1)	// P14
	($xmax $y2   0.1)	// P15
	($xmax $y3   0.1)	// P16
	($xmax $y4   0.1)	// P17
	($xmax $ymax 0.1)	// P18
	(0     $ymax 0.1)	// P19
	(0     $y4   0.1)	// P20
	(0     $y3   0.1)	// P21
	(0     $y2   0.1)	// P22
	(0     $y1   0.1)	// P23
blocks
	hex (0 1 2 11 12 13 14 23)  ($xcell $ycell1 1) simpleGrading (1 1 1)
	hex (11 2 3 10 23 14 15 22) ($xcell $ycell2 1) simpleGrading (1 1 1)
	hex (10 3 4 9 22 15 16 21)  ($xcell $ycell3 1) simpleGrading (1 1 1)
	hex (9 4 5 8 21 16 17 20)   ($xcell $ycell2 1) simpleGrading (1 1 1)
	hex (8 5 6 7 20 17 18 19)   ($xcell $ycell1 1) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (9 21 20 8)
	outlet
        type patch;
        faces
			(2 3 15 14)
    otherWalls
        type wall;
        faces
            (8 20 19 7)
			(10 22 21 9)
			(11 23 22 10)
			(0 12 23 11)
			(0 1 13 12)
			(1 2 14 13)
			(3 4 16 15)
			(4 5 17 16)
			(5 6 18 17)
			(6 7 19 18)
    frontAndBack
        type empty;
        faces
            (0 11 2 1)
			(11 10 3 2)
			(10 9 4 3)
			(9 8 5 4)
			(8 7 6 5)
			(12 13 14 23)
			(23 14 15 22)
			(22 15 16 21)
			(21 16 17 20)
			(20 17 18 19)
mergePatchPairs
Last edited by palarcon; July 19, 2019 at 09:29. Reason: Addition of supplementary information
palarcon is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
[OpenFOAM.org] OpenFOAM 5.0: sudden new compilation error on on the Titan supercomputer (Cray) wildfire230 OpenFOAM Installation 1 July 15, 2018 10:06
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 19:20
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
OpenFoam 2.1.x /2.2.0 compilation failed on Ubuntu 12.04/10 64bit keepfit OpenFOAM Installation 2 March 26, 2013 09:43
