August 28, 2019, 05:24 |
Programming custom sample utility
Raul Ciria Aylagas
Rep Power: 8 |
Hello all,
I was trying to create a postprocessing utility to calculate boundary layer parameters. What I want to do is: - iterate over each faces of a patch, - create a line normal to each face, - sample velocities over the line, - Do some calculations to compute the parameters (just some integrals along the line) - Save the values on the boundary face as a new field. My problem is that I can't find a valid function to do the sampling of the velocity over the line. Could it be possible to use the sample utility of OpenFOAM from inside another utility? Does anyone has an idea on how to do this? Thank You! Raul |
boundary layer thickness, post processing, sample utility |
Sample utility bug? For many cloud points in the sampleDict, some are neglected! | brandius | OpenFOAM Post-Processing | 10 | August 22, 2022 09:56 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 6 | November 15, 2014 18:04 |
Sample utility not working properly | titio | OpenFOAM | 2 | June 9, 2010 10:45 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 0 | February 5, 2010 12:12 |
Sample utility not working in OpenFoam1.5 dev | titio | OpenFOAM Post-Processing | 1 | December 10, 2009 02:38 |
