interface curvature in interFoam
Like Tree2Likes
  • 1 Post By ndtrong
  • 1 Post By mAlletto
Old   December 14, 2019, 01:55
Default interface curvature in interFoam
Nguyen Duy Trong
ndtrong is on a distinguished road
Hi everyone,
I have a question about interface curvature as below:
Following definition of interface curvature, \kappa is defined as:
\kappa = \nabla\cdot \vec{n}
in which \vec{n} is normal vector of interface that is defined based on volume fraction in each cell as:
\vec{n} = \frac{\nabla \cdot \alpha}{|\nabla \cdot \alpha|}
So:
\vec{n} is volVectorField and then \kappa is volScalarField, is that correct?
However, in interFoam solver, \vec{n} is defined on cell face (\vec{n_f}) as:
\vec{n_f} = \frac{(\nabla \alpha)_f}{|(\nabla \alpha)_f|}
where (\nabla\alpha)_f is defined by interpolation computation as:
(\nabla\alpha)_f = \text{fvc::interpolate}(\nabla\alpha)
then, face unit interface normal flux is defined as:
\hat{n}_f = \vec{n}\cdot S_f
with S_f is the normal vector of cell face (Note that \hat{n}_f then is a surfaceScalarField).
Then, interface curvature is defined as:
\kappa = \nabla\cdot\hat{n}_f
My question is:
- why do we need to interpolate the \nabla\alpha to cell face.
- when we mention about normal vector of interface (interface normal vector) which one is correct \vec{n} defined at cell's center or \vec{n}_f defined at cell's face?
mcfdma likes this.
ndtrong is offline   Reply With Quote
Old   December 16, 2019, 08:36
Hosein
einstein_zee is on a distinguished road
Hii there,
1. In order to be consistent with FVM, fluxes/forces or ... are calculated over the faces of the computational cell. Also note that surface tension is added as a volumetric force in momentum equation.
2. In general, VOF methods which are not tracking explicitly(by reconstructing the interface) the interface, are not representing the exact shape of the interface. This means you should not worry about which one is correct or not. As far as solution of momentum eq. is concerned the formulation should be done WRT cell faces.
hope this helps...
einstein_zee is offline   Reply With Quote
Old   December 17, 2019, 18:18
Nguyen Duy Trong
Originally Posted by einstein_zee View Post
Hii there,
hope this helps...
Dear Mr. Hosein
Thank you very much for your comments.
I have another question on comment #2. Could you please make clear on VOF methods which are not tracking explicit, why it does not represent the exact shape of interface? What are their drawback make interface not sharpen?
Old   December 20, 2019, 05:37
Michael Alletto
mAlletto will become famous soon enough
the interface is not explicit since it is calculated from the colour function alpha. One disadvantage is that if you consider also surface tension with an implicit formulation of the interface you can generate parasitic currents. A very good article explaining interfoam is this one: https://iopscience.iop.org/article/1.../1/014016/meta
ndtrong likes this.
mAlletto is offline   Reply With Quote
Old   December 22, 2019, 22:49
Nguyen Duy Trong
Dear Michael,
I thank you very much for your comment with related paper.
Can I achieve better convergence? sheaker CFX 12 September 19, 2019 15:36
extrapolating interface curvature onto the wall Saideep OpenFOAM 8 August 1, 2016 07:27
interFOAM/ sclsVOF. Interface representation. Saideep OpenFOAM Running, Solving & CFD 0 January 28, 2016 11:22
strange curvature with interFoam (comparison with Brackbill work) duongquaphim OpenFOAM Running, Solving & CFD 23 July 25, 2013 01:03
the interface reconstruction in InterFoam young_Cao OpenFOAM Running, Solving & CFD 3 June 13, 2012 06:45
