Making my custom functionObject run in parallel |
January 14, 2020, 08:52 |
David Andersson
Rep Power: 6 |
I have developed a functionObject that runs together with my modified pimpleFoam solver. I need to be able to run this set up in parallel and I am therefore wondering how this can be done, and also if there is a big effort adapting my code to do so? To solver works fine since I've just added a custom field but the functionObject is not working. The analysis runs without errors but it is completely ignoring the functionObject. Thankful for help on this one, David |
January 19, 2020, 07:38 |
Michael Alletto
Rep Power: 15 |
When writing a code in openFoam the code is executed in each processor indipendently. So the processors do not know from each other. If you want to share informations between the processors you have to use MPI commands
January 27, 2020, 12:17 |
#3 | |
David Andersson
Rep Power: 6 |
Thank you Michael for your reply!
Thanks, David |
January 27, 2020, 13:09 |
Michael Alletto
Rep Power: 15 |
I'm not aware of any documentation of the mpi command available in OpenFOAM. you find some sources in the folder src/Pstream/mpi.
What I did to find out the available function are just grep for the common mpi functions which one requires to program parallel code: reduce, gather, scatter. So just grep for this words and look how it is done in the code an copy the statements. |
January 27, 2020, 13:10 |
David Andersson
Rep Power: 6 |
Alright perfect, I will try this!
Thank you again for your help. |
January 28, 2020, 07:56 |
#6 | |
David Andersson
Rep Power: 6 |
EDIT: Sorry, you did already refer to the example codes in your first post - I missed that. Thanks! |
February 5, 2020, 06:01 |
#7 | |
David Andersson
Rep Power: 6 |
Hi Michael,
Pstream::listCombineGather(force_, plusEqOp<vectorField>()); Pstream::listCombineScatter(force_); I also have a hard time understanding the last argument in the listCombineGather statement, as far as I understand the "plusEqOp<> is a "plus equal operator" that basically does +=. Depending on what I do with my lists do I need to use a different Operator then? Also, do you possibly know the difference between "listCombineGathar/Scatter", "combineGather/Scatter" and "gather/scatter"? Thanks, David |
February 7, 2020, 14:04 |
Michael Alletto
Rep Power: 15 |
Ok in the function object the variable force_ is a vectorField. What it is actually it is a list of vectors.
What you they what to achieve is to sum each entry of the vectorField force_[i] over all processors. this is achieved by Code:
Pstream::listCombineGather(force_, plusEqOp<vectorField>()); since it is a gather this is only done by the master processor. So the master processor collects all the data and sum over all processors. In order to send the combined data ( plusEqOp is the operator += ) to all other processors. This is done by the code lines this is achieved by Code:
Pstream::listCombineScatter(force_); combineGather/scatter do the same things as above but for a single variable (e.g. a vector) Hope it helps. What helped me a lot to understand all the commands is to use a small test case and put some Pout statement in the code. So you exactly see what's happening in the processors. Best Michael |
February 10, 2020, 03:39 |
#9 | |
David Andersson
Rep Power: 6 |
Hi Michael,
First of all - thank you for your answer, it helped me clarify some things. However, I need som further help. Quote:
Let me post a small snippet of my code and maybe you can help me clarify where I need to gather / scatter and what lists I need to gather / scatter. Code:
scalar n = std::round(mesh_.time().value()/mesh_.time().deltaT().value()); //- Reading current pressure values for selected faces facePressures = Foam::List<double>(noFaces, 0.0); int i = 0; forAll(p.boundaryField(), patchIt){ if(patchSet_[patchIt]){ forAll(p.boundaryField()[patchIt],faceIt){ facePressures[i] = p.boundaryField()[patchIt][faceIt]; i ++; } } } //- Calculating meanvalues Foam::List<double> delta = facePressures - meanVec; for(int i=0; i<noFaces; i++){ meanVec[i] += delta[i]/n; } My problem here is that I don't undertand what parts of my code that needs to be gathered/scattered and what I can leave untouched. It would be great if you could help me out here and I think if you did I should be able to implement it on the rest of my code by myself. Thank you in advance. Cheers, David |
February 10, 2020, 04:02 |
#10 |
Michael Alletto
Rep Power: 15 |
If you want to calculate the mean value of each face you don't need MPI communication. For this you don't need informations of other processors
February 10, 2020, 04:03 |
#11 | |
David Andersson
Rep Power: 6 |
//David |
February 10, 2020, 06:33 |
#12 |
Michael Alletto
Rep Power: 15 |
Hm. Gather is used if the master processors needs informations of all other professors and scatter is used when you want to send informations from the master processor to all other. Maybe if you can provide an example where MPI communication is needed I can help you
February 10, 2020, 07:46 |
#13 | |
David Andersson
Rep Power: 6 |
My code is quite long so I therefore thought I could post just a part of it so that you can help me and then I can implement that on the full code by myself. I therefore again post the snippet where I compute the mean value and the quesion is now - how would I adapt this code to work in parallel? Code:
const volScalarField& p = lookupObject<volScalarField>("p"); //- Initializing variables, vectors and matrices at t = dT if(std::abs(mesh_.time().value()-mesh_.time().deltaT().value()) < 0.01){ forAll(p.boundaryField(),patchIt){ if(patchSet_[patchIt]){ forAll(p.boundaryField()[patchIt],faceIt){ noFaces ++; } } } //- Constructing vectors meanVec = Foam::List<double>(noFaces,0.0); }else{ scalar n = std::round((mesh_.time().value()-mesh_.time().deltaT().value())/mesh_.time().deltaT().value()); //- Reading face values facePressures = Foam::List<double>(noFaces, 0.0); int i = 0; forAll(p.boundaryField(), patchIt){ if(patchSet_[patchIt]){ forAll(p.boundaryField()[patchIt],faceIt){ facePressures[i] = p.boundaryField()[patchIt][faceIt]; i ++; } } } //- Calculating meanvalues and standard deviation Foam::List<double> delta = facePressures - meanVec; for(int i=0; i<noFaces; i++){ meanVec[i] += delta[i]/n; } } Thanks, David |
February 10, 2020, 14:55 |
#14 |
Michael Alletto
Rep Power: 15 |
Is the correlation between variable defined locally or not. So if you want to calculate the correlation between the pressure and a given velocity component locally at each face you do not need MPI commands. Each processor does this individually. You just need it at the end when you want to write out the results in a single file
February 10, 2020, 15:55 |
#15 | |
David Andersson
Rep Power: 6 |
Good question... The correlation values is a list of lists (a matrix) that I store and update each step. I guess is local then?
myField.boundaryFieldRef()[patchIt][faceIt] = meanVec[i] + stdVec[i]*corrMat[i]; //David P.S. Thanks for your patient with me. I am quite new to programming in OpenFOAM. I appreciate your help a lot. |
February 10, 2020, 16:52 |
#16 |
Michael Alletto
Rep Power: 15 |
Do you have written down the equation of the quanties you want to compute. But anyway if you want to perform calculations between variables defined at the same location you don't need MPI. For the code you provided you don't need any communication.
February 11, 2020, 02:18 |
#17 |
David Andersson
Rep Power: 6 |
Yes I have written all code, in one function file. I am only reading values from the solver doing a lot of computations in the function file and then sending one list back to the solver. Therefore I thought I need to gather from the solver, do my calculations and then scatter back to the solver?
February 11, 2020, 04:16 |
#18 |
Michael Alletto
Rep Power: 15 |
No for this you have only to register the objects you want to be seen by the solver in the object register
February 11, 2020, 04:24 |
#19 | |
David Andersson
Rep Power: 6 |
EDIT: I just tried to run the code above in parallel and it didn't work. I added Code:
Info << meanVec.size() << endl; I therefore added this line instead to see what was on each processor Code:
Pout << meanVec.size() << endl; Code:
[4] 0 [3] 0 [2] 0 [1] 0 [0] 0 [5] 407 [27] 0 [20] 0 [14] 0 [28] 0 [18] 313 [13] 0 [24] 0 [23] 0 [15] 0 [25] 0 [22] 0 [12] 0 [26] 0 [21] 0 [16] 0 [29] 0 [19] 384 [17] 0 [6] 0 [11] 0 [7] 0 [10] 0 [8] 0 [9] 304 Last edited by sippanspojk; February 11, 2020 at 11:09. |
February 11, 2020, 14:19 |
#20 |
Michael Alletto
Rep Power: 15 |
Some info about the object registry https://openfoamwiki.net/index.php/O...objectRegistry.
It's a database where the objects are stored which should be globally visible like the mesh, the velocity, the pressure a.s.o. |
parallel |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
OpenFOAM can't be run in parallel in cluster | sibo | OpenFOAM Running, Solving & CFD | 4 | February 21, 2017 16:29 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
