Allrun always running in background?
Like Tree1Likes
  • 1 Post By clapointe
Old   April 21, 2020, 05:36
Default Allrun always running in background?
geth03 is on a distinguished road
hi,
i'm trying to create an Allrun-file for my case which i'm running in parallel mode. the cores i use vary.
one way to go would be:
cd ${0%/*} || exit 1 # Run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
runApplication decomposePar
runParallel $(getApplication)
when i do this, OF creates log files and saves the output right there, the solver is running in the background, so i need to reload the log-file the whole time, which is annoying, and also the files can get large really quickly.
1. i don't want to save the output in a log file.
2. i want to see the calculation on my terminal as i would see it when i would run it with typing in the solver name etc.
any ideas how that can be done?
i already tried the following:
decomposePar
nProcs=$(getNumberOfProcessors)
mpirun -n "$nProcs" solvername -parallel
OF doesn't recognize "$nProcs", also tried "nProcs" and nProcs, $nProcs.
i could also type in the number of cores i use, then it works, but i want to automate stuff, therefore doesn't want to open Allrun for each case.
Thanks and regards
geth03 is offline   Reply With Quote
Old   April 21, 2020, 15:22
clapointe is on a distinguished road
Looking at the RunFunctions script, you'll see that the command is actually
mpirun -np $nProcs $APP_RUN -parallel
Obviously you'll need to replace $APP_RUN with the name of your solver, but the rest of the command will work.
Caelan
geth03 likes this.
clapointe is offline   Reply With Quote
Old   April 22, 2020, 04:24
thanks,
decomposePar
mpirun -np $nProcs solvername -parallel
that actually worked,
when i use the terminal i just need to type in
mpirun -n processorNumber solvername -parallel
so the only adjustment was -np instead of -n.
License trouble: ANSLIC_ADMIN, FLEXlm not running, but two lmgrd processes running! dancoz87 ANSYS 17 November 14, 2016 01:10
how to run the propeller Tutrial immortality OpenFOAM Running, Solving & CFD 10 February 22, 2014 09:33
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running sunliming OpenFOAM Bugs 21 November 22, 2013 03:38
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 04:59
Problems in a Background running of Intel Fortran Minsuk Choi Main CFD Forum 2 February 11, 2005 04:55
