Porous Media with rhoCentralFoam
Like Tree2Likes
  • 2 Post By shock77
Old   May 7, 2020, 11:48
Default Porous Media with rhoCentralFoam
shock77 is on a distinguished road
I have noticed that rhoCentralFoam has no porosity treatment unlike sonicFoam or rhoPimpleFoam. Since I have the best results with rhoCentralFoam I would like to add the porosity treatment.
I want to use the Darcy-Forchheimer model explicitly by using fvOptions, which works well for other solvers except rhoCentralFoam.
I have noticed, that in rhoPimpleFoam UEqn.H fvOptions is mentioned:
// Solve the Momentum equation
MRF.correctBoundaryVelocity(U);
tmp<fvVectorMatrix> tUEqn
    fvm::ddt(rho, U) + fvm::div(phi, U)
  + MRF.DDt(rho, U)
  + turbulence->divDevRhoReff(U)
    fvOptions(rho, U)
fvVectorMatrix& UEqn = tUEqn.ref();
UEqn.relax();
fvOptions.constrain(UEqn);
if (pimple.momentumPredictor())
    solve(UEqn == -fvc::grad(p));
    fvOptions.correct(U);
    K = 0.5*magSqr(U);
while in rhoCentralFoam.C it is not:
        // --- Solve momentum
        solve(fvm::ddt(rhoU) + fvc::div(phiUp));
        U.ref() =
            rhoU()
           /rho();
        U.correctBoundaryConditions();
        rhoU.boundaryFieldRef() == rho.boundaryField()*U.boundaryField();
        if (!inviscid)
            solve
                fvm::ddt(rho, U) - fvc::ddt(rho, U)
              - fvm::laplacian(muEff, U)
              - fvc::div(tauMC)
            rhoU = rho*U;
Since my flow is viscous, I should concentrate on the if statement. Replacing it by
        if (!inviscid)
            solve
              - fvc::div(tauMC) ==    fvOptions(rho, U)
            rhoU = rho*U;
doesn't seem to work.
I would be glad to hear your advice!
Regards,
shock77
shock77 is offline   Reply With Quote
Old   May 8, 2020, 08:00
So what I want to to is to add the additional sink term of the darcy model or better the darcy forchheimer model. Unfortunately I dont know how to do it.
https://openfoamwiki.net/index.php/DarcyForchheimer
I hope someone has more experience than me.
Old   May 9, 2020, 18:54
I was mistaken, it works well.
For anyone with the same issue:
Just add the additional sink term with fvOptions(rho, U) like I did. Of course you have to include fvOption.H in rhoCentralFoam.C or your new solver! Compile it and use it like the other solvers.
jherb and HPE like this.
Thermal non-equilibrium porous media model with conjugate heat transfer Hexahedron FLUENT 9 February 22, 2023 02:55
use of porous media with sonicFoam or rhoCentralFoam Calmly OpenFOAM Running, Solving & CFD 6 May 7, 2020 11:12
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
