Updating a solver from OF211 to OF6
Old   January 9, 2020, 04:19
Default Updating a solver from OF211 to OF6
X
mcfdma is on a distinguished road
Hello.
Topic: Electrohydrodynamic solver
I am trying to update a functional code (originally developed on OF211) from EHDFoam to OF6 (my own code) EHDFoam .
EHDFoam contains few validation cases. I am able to get similar results for charge bump relaxation case, and conducting cylinder case (both found in cases/validation_v2).
However, when I run the BjorklundBreakupDrop case (using my modified updated solver on OF6) which deals with electric field interaction and fluid-fluid interface, my results are not similar as shown in the images below. (OF211 was updated to OF231 which showed similar results according to the paper [1])
I would appreciate if anyone could help me with this.
[1] https://ris.utwente.nl/ws/portalfile...l_draft_v1.pdf
mcfdma is offline   Reply With Quote
Old   May 13, 2020, 04:16
Bryan Hoon
bryanh is on a distinguished road
Hi Mmalik,
I am also trying to create an EHD solver on OF but am fairly new to the software. I have tried running the validation cases using your code in OF6 but have ran into a string of errors when running the ./Allrun script.
If it is possible, could you please share the modified case files you have used in validating your code?
Thank you!
bryanh is offline   Reply With Quote
ehdfoam, electrohydrodynamic, of211, of6, solver development
Population Balance Modeling (PBM) - Ansys Fluent chittipo FLUENT 164 November 18, 2023 11:54
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 05:21
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
