coupling chtmultiregion with a incompressible solver |
May 28, 2020, 18:40 |
Sam
Rep Power: 7 |
Hey guys,
I have a modified incompressible solver (interThermalPhaseChangeFoam) that I wish to couple with conjugate heat transfer. The only issue is that chtmultiregion is compressible and the coupled BC is for compressible. Is this a realistic possibility to do. Thanks Sam |
May 29, 2020, 17:59 |
Herpes Free Engineer
Rep Power: 12 |
The question is that how do you plan to handle the temperature field (cht*) in the incompressible solver? In which way do you expect the heat transfer will manifest itself on the incompressible flow? Via Boussinesq approximation of density? If no clear answers you have for these aspects, I would embed my modifications into a compressible solver, instead.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 29, 2020, 18:05 |
Sam
Rep Power: 7 |
Thanks for the advice. I guess it is something that I will not have time to resolve at this moment. I will move onto something else instead.
Incompressible Solver - What does this mean? | CellZone | Main CFD Forum | 12 | January 14, 2019 15:06 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Coupling to external code using MPI calls from within a solver | Regis_ | OpenFOAM Programming & Development | 0 | October 31, 2017 10:50 |
Modify compressible solver to incompressible | mingzhao | OpenFOAM Programming & Development | 0 | September 18, 2015 17:46 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
