Bug in Artificial Compressibility Method using Dual-Time Stepping
Like Tree1Likes
  • 1 Post By Jesus.M
Old   June 20, 2020, 07:02
Default Bug in Artificial Compressibility Method using Dual-Time Stepping
Jesús Miguel Sánchez
Jesus.M is on a distinguished road
Hello OpenFOAM Community,
I am implementing the Artificial Compressibility method with dual-time stepping. I finished the code by adding a for loop in order to advance the solution in real time besides the pseudo-time stepping that this method uses. Therefore, I had to set also a counter for the real time and do several modifications to the code. I fixed some previous bugs that kept me from having a clean compilation. Once I had a clean compilation, I tried the code and it runs, but it does not print the solution for the specified time-step... Any suggestion of what it can be causing this problem?
Here's the code for more clarity.
int main(int argc, char *argv[])
        #include "postProcess.H"
        #include "addCheckCaseOptions.H"
        #include "setRootCaseLists.H"
        #include "createTime.H"
        #include "createMesh.H"
        #include "createControl.H"
        #include "createFields.H"
        #include "initContinuityErrs.H"
        #include "CourantNo.H"
        #include "readTimeControls.H"
        #include "setInitialDeltaT.H"
    scalar maxCoRealTime = runTime.controlDict().lookupOrDefault<scalar>("maxCoRealTime", 1.0);
    scalar realDeltaT = runTime.controlDict().lookupOrDefault<scalar>("realDeltaT", GREAT);
    scalar CoNumRealTime = 0.0;
    #include "CourantNoRealTime.H"
        Info<< "\nStarting time loop\n" << endl;
    //declaration Time Variables
        auto maxIterRealTime = runTime.controlDict().lookupOrDefault<scalar>("maxIterRealTime",1);
    auto maxIterPseudoTime = runTime.controlDict().lookupOrDefault<scalar>("maxIterPseudoTime",1);
    decltype(realDeltaT) timeTotalRealTime = 0.0;
    auto runRealTime = runTime.timeIndex();
    runRealTime = 0;
    //declaration of fluid properties
    decltype(U) Udt1 = U;
    decltype(U) Udt0 = U;
    //Real-time step
    for(auto i = decltype(maxIterRealTime){0}; i < maxIterRealTime; ++i)
        ++runRealTime;
        #include "readRealTimeControls.H"
        #include "setRealDeltaT.H"
        Udt0 = Udt1; // Updating U at real time.
        //Pseudo-time step
        while (runTime.timeIndex() < maxIterPseudoTime)
            ++runTime;
            //Time derivative
             auto dualDt = dimensionedScalar("dt_real", dimTime, realDeltaT);
                 Udt1    = U;
                 dt_ddt  = (Udt1 - Udt0) / dualDt;
            //CFL-based time-step
                #include "setDeltaT.H"
                Info<< "Time = " << runTime.timeName() << nl << endl;
                //Continuity Equation
            phi = fvc::interpolate(U) & mesh.Sf();
            fvScalarMatrix pEqn
              fvm::ddt(p) + beta * fvc::div(U)
            //pEqn.setReference(pRefCell, pRefValue);
            pEqn.solve();
            #include "continuityErrs.H"
            p.correctBoundaryConditions();
            //Momentum Equation
                fvVectorMatrix UEqn
              fvm::ddt(U) + fvm::div(phi,U) - fvm::laplacian(nu,U)
            solve(UEqn == -fvc::grad(p) - dt_ddt);
        runTime.printExecutionTime(Info);
        //Update Real time and reset pseudo-time
        timeTotalRealTime += realDeltaT;
        runTime.setTime(timeTotalRealTime, runRealTime);
            runTime.write();
        runTime.setTime(0.0, 0);
    Info<< "End\n" << endl;
    return 0;
Thank you
Jesus.M is offline   Reply With Quote
Old   June 23, 2020, 06:49
Hello OpenFOAM community,
I have figured out that the command runTime.write() does not work. However, I don't know the reason why.
Does anyone know why it can stop working?
Old   June 26, 2020, 06:52
I have found the problem. I will post the solution for anyone who encounters the same problem. The code ran fine. When you are doing dual-time stepping, you have to set the writeControl inside the controlDict file to timeStep.
Then, OpenFOAM will write every time-step in real time.
scleakey likes this.
dual time stepping method
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 41 August 23, 2023 02:48
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 13:47
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
Dual Time Stepping Method X. Ye Main CFD Forum 1 September 23, 1999 04:05
