July 15, 2020, 14:11 |
#21 |
Carlos Rubio Abujas
Rep Power: 9 |
I'm sorry but I think we are talking about different versions of the code. What loop are you talking about? In the final version there's no loop at all! As we've been back and from with the code a lot this time maybe there could be some misunderstanding.
I've tried this version of the code and worked for me. I've added a bunch of CUSTOM: flags to have some insight of the code behavior. Code:
inlet { type codedFixedValue; value uniform 0; name CardiacImpuse; code #{ const scalar &t = this ->db().time().value(); const scalar dt = this ->db().time().deltaTValue(); const surfaceScalarField& phi = db().lookupObject<surfaceScalarField>("phi"); const fvsPatchField<scalar>& phip = patch().patchField<surfaceScalarField,scalar> (phi); const fvsPatchField<scalar>& phip_last = patch().patchField<surfaceScalarField,scalar> (phi.oldTime()); // Constants const scalar C=1.16e-05; const scalar R1=1.64e+03; const scalar R2=1.79e+05; const scalar p_0=7.55; const scalar Q_0=1.03e-4; const scalar T_REF=0.1; // Static variables static scalar integrand (0); static scalar current_time (0); scalar tau = std::fmod(t, T_REF); // Check if the timestep in new if (current_time < t) { // Update the stored timestep current_time = t; Info << "CUSTOM: current_time=" << current_time << nl << "CUSTOM: dt=" << dt << nl << "CUSTOM: tau=" << tau << endl; // Update the integrand with the previous value integrand += (exp(tau/(R2*C))*gSum(phip_last)*dt); Info << "CUSTOM: Updated integrad to " << integrand << endl; // Check for reset condition if (tau < dt) { integrand = 0; Info << "CUSTOM: Reseting the integrand" << endl; } } operator ==(R1*gSum(phip)+exp(-tau/(R2*C))*((p_0-R1*Q_0)+(1/C)*integrand)); #}; } |
July 15, 2020, 15:29 |
#22 |
Rep Power: 6 |
Oh No, I'm sorry, my mistake, I meant in the IF, not loop!: Eek:
The simulation has now ended and it worked!!! I still have to fix something, but finally the pressure values are correct! I don't know how to thank you, you were very kind. |
July 17, 2020, 06:00 |
#23 |
Rep Power: 6 |
I am very sorry to to disturb again.
Unfortunately there is one last problem. I checked the values, the code compiles without errors and the pressures are now correct, but it does not read the IF. So it do not apply the correction to t = 1 with integrand=0. I have tried other order: if (tau<dt) { operator ==(7.55); integrand=0; } and this too: const volScalarField & p = db (). lookupObject <volScalarField> ("p"); const fvPatchField<scalar> & pip = patch().patchField<volScalarField,scalar> (p); fvPatchField& P_new=const_cast<fvPatchScalarField&>(pip); if ( tau<dt) { forAll (P_new , facei) { P_new[facei]=7.55; } } but it continues the calculation ignoring them, the final pressure always remains different from 7.55 and it's always the same value. How is it possible? I want that at time = 1 the pressure is 7.55. Last edited by Neb; July 17, 2020 at 10:45. |
July 20, 2020, 18:01 |
#24 |
Rep Power: 6 |
I solved the code. : D: D: D
Thank you very much for all the suggestions have been very useful! |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
