September 23, 2020, 17:53 |
Error: Redefinition of function
Saumava Dey
Rep Power: 5 |
I have written two functions for Modified Bessel Functions of First and Second Kind of Order 0 as besselI0 and besselK0 respectively.
The function besselK0 calls the function besselI0 within itself and has been included as a header file. The codes are as follows: namespace Foam { scalar besselI0(scalar X) { const scalar A1 = 1.0; const scalar A2 = 3.5156229; const scalar A3 = 3.0899424; const scalar A4 = 1.2067492; const scalar A5 = 0.2659732; const scalar A6 = 0.0360768; const scalar A7 = 0.0045813; const scalar B1 = 0.39894228; const scalar B2 = 0.01328592; const scalar B3 = 0.00225319; const scalar B4 = -0.00157565; const scalar B5 = 0.00916281; const scalar B6 = -0.02057706; const scalar B7 = 0.02635537; const scalar B8 = -0.01647633; const scalar B9 = 0.00392377; scalar T; scalar I; if (mag(X) < 3.75) { T = sqr(X/3.75); I = A1 + T*(A2 + T*(A3 + T*(A4 + T*(A5 + T*(A6 + T*A7))))); } else { T = 3.75/mag(X); I = B1 + T*(B2 + T*(B3 + T*(B4 + T*(B5 + T*(B6 + T*(B7 + T*(B8 + T*B9))))))); I = (I*exp(mag(X)))/sqrt(mag(X)); } return I; } } =============================================== #include "besselI0.H" namespace Foam { scalar besselK0(scalar X) { const scalar A1 = -0.57721566; const scalar A2 = 0.42278420; const scalar A3 = 0.23069756; const scalar A4 = 0.03488590; const scalar A5 = 0.00262698; const scalar A6 = 0.00010750; const scalar A7 = 0.00000740; const scalar B1 = 1.25331414; const scalar B2 = -0.07832358; const scalar B3 = 0.02189568; const scalar B4 = -0.01062446; const scalar B5 = 0.00587872; const scalar B6 = -0.00251540; const scalar B7 = 0.00053208; scalar T; scalar K; if (X <= 2.0) { T = sqr(X/2.0); K = -(log(X/2.0)*besselI0(X)) + A1 + T*(A2 + T*(A3 + T*(A4 + T*(A5 + T*(A6 + T*A7))))); } else { T = 2.0/X; K = B1 + T*(B2 + T*(B3 + T*(B4 + T*(B5 + T*(B6 + T*B7))))); K = K/(exp(X)*sqrt(X)); } return K; } } =============================================== While compiling I get the following error: In file included from besselK0.H:11:0, besselI0.H: In function ‘Foam::scalar Foam::besselI0(Foam::scalar)’: besselI0.H:13:9: error: redefinition of ‘Foam::scalar Foam::besselI0(Foam::scalar)’ scalar besselI0(scalar X) ^~~~~~~~ In file included from besselK0.H:11:0, besselI0.H:13:9: note: ‘Foam::scalar Foam::besselI0(Foam::scalar)’ previously defined here scalar besselI0(scalar X) =============================================== I am not being able to figure out where am I getting it wrong. I seek help in recognizing the error and how to get out of it. Regards, Saumava |
September 24, 2020, 06:12 |
Rep Power: 7 |
Hey, could you share the whole header file BesselI0.H? Is the header file included elsewhere? Is BesselIO.H including the preprocessor directive ->
#ifndef BESSELI0_H #define BESSELI0_H //your awesome function here #endif |
September 24, 2020, 08:08 |
Saumava Dey
Rep Power: 5 |
You got this right. Adding the header guards worked.
Thanks a lot. |
September 24, 2020, 19:23 |
#4 | |
Mark Olesen
Rep Power: 40 |
To help the compiler out, the various A, B constants should be constexpr. Finally, reduce the use of additional (non-const) variables to help convince the compiler some more. For example, Code:
namespace Foam { inline scalar besselI0(const scalar X) { constexpr scalar A1 = 1.0; constexpr scalar A2 = 3.5156229; ... if (mag(X) < 3.75) { const scalar T = sqr(X/3.75); return A1 + T*(A2 + T*(A3 + T*(A4 + T*(A5 + T*(A6 + T*A7))))); } else { const scalar T = 3.75/mag(X); return (B1 + T*(B2 + T*(B3 + T*(B4 + T*(B5 + T*(B6 + T*(B7 + T*(B8 + T*B9)))))))) * exp(mag(X)/sqrt(mag(X); } } } |
error, function |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
