1D Stefan problem validation of new solver
Old   September 24, 2020, 11:13
Default 1D Stefan problem validation of new solver
Huihui Xiao is on a distinguished road
Hello everyone,
I developed a new evaporation solver based on some excellent solvers (interFoam, interPhaseChangeFoam and evapVOFHardt), and when I validated the 1D Stefan problem, the velocity field is not correct (see attached), and some key code can be found as follows:
1. Source terms in alphaEqn (the same as the source terms in interPhaseChangeFoam)
// explicit source term
volScalarField Su
IOobject
"Su",
runTime.timeName(),
mesh
- dotM/rho1
//zeroField Sp;
// implicit source term
volScalarField Sp
IOobject
"Sp",
runTime.timeName(),
mesh
fvc::div(phi) - dotM*(1.0/rho2-1.0/rho1)
2. UEqn with new source terms
fvVectorMatrix UEqn
fvm::ddt(rho, U)
+ fvm::div(rhoPhi, U)
- fvm::Sp(fvc::ddt(rho) + fvc::div(rhoPhi), U) // new
+ MRF.DDt(rho, U)
+ turbulence->divDevRhoReff(rho, U)
fvOptions(rho, U)
3. TEqn
Info << "Solve TEqn" << endl;
volScalarField k = alpha1*k1 + alpha2*k2; // one-field formulation
volScalarField rhoCp = alpha1*rho1*cp1 + alpha2*rho2*cp2;
// one-field formulation; rho:density; cp: specific heat capacity
surfaceScalarField alphaPhi = (rhoPhi-phi*rho2)/(rho1-rho2);
// hint: rhoPhi = alpha1*rho1*phi + (1-alpha1)*rho2*phi
// rho1 must not be equal to rho2
surfaceScalarField rhoCpPhi = alphaPhi*(rho1*cp1-rho2*cp2)+phi*rho2*cp2;
// rhoCpPhi = alpha1*rho1*cp1*phi + (1-alpha1)*rho2*cp2*phi
fvScalarMatrix TEqn
fvm::ddt(rhoCp,T)
+ fvm::div(rhoCpPhi,T)
- fvm::laplacian(k,T)
fvm::Sp(fvc::ddt(rhoCp) + fvc::div(rhoCpPhi),T)
// new source term 01 (Coupled to mass source term)
+ fvm::Sp(TEqnSou,T)
- TEqnSou*Tsat
// new source term 02 (cooling due to evaporation)
TEqn.relax();
TEqn.solve();
Info<< "min/max(T) = " << min(T).value() << "; "
<< max(T).value() <<endl;
4. pEqn
fvScalarMatrix p_rghEqn
fvm::laplacian(rAUf, p_rgh) == fvc::div(phi) - dotM*(scalar(1.0)/rho2 - scalar(1.0)/rho1) //new
5. source terms (modified from evapVOFHardt)
volScalarField jLoc = (T-Tsat)/(Rint*hEvap);
dotM = jLoc*magGradAlpha;
forAll(alpha1.ref(),iCell)
if (magGradAlpha.ref()[iCell] > 0.0)
dotM[iCell] *= 1.0;
// only set source terms in interface cells
else
dotM[iCell] *= 0.0;
// the second term of the TEqn
TEqnSou = -magGradAlpha/Rint;
6. main program
#include "sourceTerms.H"
evapRate = fvc::domainIntegrate(dotM);
#include "TEqn.H"
Info<< "Evaporation rate is = " << evapRate.value() << "kg/s at t = " << runTime.timeName()
<< "s" << endl;
If anyone know how to fix the problem, it will be best, and if I have something wrong in my code, please let me know.
Many thanks,
Huihui
Huihui Xiao is offline   Reply With Quote
Old   February 8, 2021, 10:10
H.Ham
kimou is on a distinguished road
You work on 1D twho-phase-flow probleme, , Me too, i work on 1D two-phase-flow but compressible configuration . I hope that you resolve your problem
Please, I would like to know how you chose your discretizations (fvSchemes and fvSolution) for your problem ??
best regret,
kimou is offline   Reply With Quote
evaporation, vof
Problem with validation of regionCouple solver tladd OpenFOAM Verification & Validation 0 May 22, 2014 18:09
Is there a problem in the Euler solver? Combas SU2 4 March 28, 2014 15:48
[ANSYS Meshing] Problem with axisymmetric solver Rasel ANSYS Meshing & Geometry 0 June 20, 2012 04:35
mesh.update problem in a new FSI solver ICL OpenFOAM 0 October 8, 2011 14:16
patching problem unsteady solver yellow-stuff Main CFD Forum 0 September 25, 2009 01:26
