October 8, 2020, 07:21 |
Add a new tranport model
semmana oualid
Rep Power: 7 |
Dear foeamers
I working on free surface flow cases for non newtonian fluids. The rheological model I want to work on, is not integrated in any openfoam version. I asking for assistance and support with examples and guides how to add a new model to openfoam and run the cases with that models. |
October 10, 2020, 09:03 |
Klaus
Rep Power: 22 |
The easiest way is usually to copy and rename the source code of the most similar model already implemented in OpenFOAM, then modify it as required.
I this case, https://www.openfoam.com/documentati...anIcoFoam.html could be a starting point. |
October 10, 2020, 09:49 |
semmana oualid
Rep Power: 7 |
Hi klausb,
Thank you for your reply. can you assist me with free surface flow case with non-newtonian fluid. Code or study case? |
October 11, 2020, 07:49 |
Klaus
Rep Power: 22 |
Which "rheological model" do you want to work with?
Do you have a paper describing the model? Have you ever compiled an OpenFOAM library or application? |
October 12, 2020, 12:33 |
semmana oualid
Rep Power: 7 |
Thank you and sorry for the late reply.
I am beginner user with basic programming knowledge. I want to work with modified Bingham model. Do you have any related guides or cases you believe that can help me. |
October 12, 2020, 14:24 |
Klaus
Rep Power: 22 |
Before you start reinventing something, would this implementation meet your requirements? https://github.com/fppimenta/rheoTool
October 12, 2020, 14:40 |
semmana oualid
Rep Power: 7 |
Thank you again,
From the tool you mentioned, I shall learn from it and try to do my cases based on those solvers. Last edited by semmana oualid; October 13, 2020 at 19:32. |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
add a fuel cell model in ansys fluent 15 | msdkhl | FLUENT | 0 | June 15, 2016 09:14 |
Add Singhal model into interPhaseChangeFoam | zhouhoucun | OpenFOAM Running, Solving & CFD | 0 | April 28, 2015 04:32 |
Add additional scalar to turbulence model | john_w | OpenFOAM | 1 | December 23, 2010 12:45 |
