Momentum predictor UEqn.H
Old   December 3, 2020, 12:44
Question Momentum predictor UEqn.H
nikhil108's Avatar
Nikhil
nikhil108 is on a distinguished road
Hallo Foamers,
I have a small doudt. In UEqn.H, in solvers where momentum predictor setting exists in pimple loop. If momentum predictor is set to no then the Right-hand side of the momentum equation is not solved (skipped because of if loop). But, I dont understand, in any case, we need to solve whole momentum equation to get U right? . Why we skip gravity and dp term ? what does this mean
     tmp<fvVectorMatrix> tUEqn
         fvm::ddt(rho, U) + fvm::div(phi, U)
       + MRF.DDt(rho, U)
       + turbulence->divDevTau(U)
         fvOptions(rho, U)
     fvVectorMatrix& UEqn = tUEqn.ref();
     UEqn.relax();
     fvOptions.constrain(UEqn);
// In here
     if (pimple.momentumPredictor())
         solve
             UEqn
             fvc::reconstruct
                   - ghf*fvc::snGrad(rho)
                   - fvc::snGrad(p_rgh)
                 )*mesh.magSf()
         fvOptions.correct(U);
         K = 0.5*magSqr(U);
nikhil108 is offline   Reply With Quote
Old   December 4, 2020, 02:50
Cyp
Cyprien
Cyp is on a distinguished road
Dear Nikhil,
When you turn off momentumPrediction, you do no solve the momentum equation.
If you look at the predictor-corrector solution algorithms used in CFD (PISO, SIMPLE, PIMPLE...), basically you do the following sequence:
- Discretize the momentum equation and form a matrix for U (optionnaly inverse this matrix to have a first guess of U)
- Form a matrix for p. This matrix depends on the coefficients of the matrix for U. Inverse the matrix for p.
- Correct the value of U point-wised based on the updated pressure field.
- Iterate until you converge.
- March in time
So, when you turn off momentumPrediction, you do update the coefficients in the matrix for U, but you do not inverse this matrix.
Cheers,
Cyprien
Cyp is offline   Reply With Quote
Old   December 4, 2020, 07:41
nikhil108's Avatar
Nikhil
Hallo Cyprien,
Thanks for the explanation. Yah! now it's crystal clear.
cheers,
nick.
momentum equation, piso, ueqn.h
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 16, 2020 23:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Spray total droplet momentum calculation help tarnsharma AVL FIRE 0 July 19, 2012 08:17
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
