Looping on Boundary faces all processors
Like Tree1Likes
  • 1 Post By fedez91
Old   December 10, 2020, 12:50
Default Looping on Boundary faces all processors
siefer92 is on a distinguished road
Howdy yall, I'm having some issues with looping over some boundary cells in simple test case using 32 processors.
I have a volScalarField called Test_Q
When I try to modify values on every cell (not boundary yet) in the field I use the following code snippit. I call this code on if(runTime.outputTime()), only running for 100 timesteps @ 10 I/O calls per run, thus simplifying my test case.
//      forAll(Test_Q, celli)
//      Info<< "CELLID IS " << celli << " CELL VALUE WAS " << testQ[celli] <<"\n" <<endl;
//      Test_Q[celli] += .001;
//      Info<< "CELLID IS " << celli << " CELL VALUE IS " << testQ[celli] <<"\n" <<endl;
Using paraview to inspect the result I can confirm it is working as intended. (The log file writes also show this)
When trying to execute a similar operation on a boundary, constrained to the boundary named "obstacle", I use the following code:
                                label patchID =mesh.boundaryMesh().findPatchID("obstacle");
                        forAll(Test_Q.boundaryField()[patchID], facei)
                                Info<< "FaceID IS " << facei << " Boundary Value Was " << Test_Q.boundaryField()[patchID][facei] <<"\n" <<endl;
                                Test_Q.boundaryFieldRef()[patchID][facei] += .001;
My initial runs are decomposed on 32 cores and the decomposition is show from paraview in picture 32_decomposed:
The boundary loop never gets called as it's likely only looping on proc0 which has no "obstacle" patch faces on it
When I run serially the code functions and the target boundary increases in value by .001 per I/O step. See img below:
Can anybody inform what I am doing wrong? The modifications are being made in the solver and recompiled each time. My thought running the solver in parallel would just "make forAll function in parallel". Naïve right?
EDIT** should note that I did use the search function and found Looping over a volScalarField in a parallel run
More or less looking for an explanation / discussion on the use of reduce, mesh.C() and the openFOAM parallel paradigm
siefer92 is offline   Reply With Quote
Old   December 11, 2020, 09:09
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
It would be helpful if you explained what you want to accomplish. Are you trying to bump the level of the entire field, but without a += operation. Do you really want to change the values on all boundaries (cyclic, processor, slip etc). Do you need to change each face and cell individually, or can you work with field values....
olesen is offline   Reply With Quote
Old   December 11, 2020, 12:56
So I am just integrating OpenFOAM's topology modification capabilities in to a solver that I am assembling.
The volScalarField Test_Q is a fill in for what will eventually be erosion values predicted by a model. The Test_Q field increases by a value of .001 (think of this as a prescribed erosion rate for now) at each I/O step (for debugging purposes so I can discriminate the I/O steps in paraview). I only run 100 timsteps @ I/O / 10 Timesteps for a quick turn-around.
I should note that I have code that functions as intended, but I'd like to truly understand my code
                         // Here the erosion is mapped onto the surface normal vector components (need to divide erosion by patch area)
                        forAll(mesh.C().boundaryField()[patchID], facei)
                                Test_Q_Vect.boundaryFieldRef()[patchID][facei].component(0) = Test_Q.boundaryFieldRef()[patchID][facei]*(mesh.Sf().boundaryField()[patchID][facei].component(0) / mesh.magSf().boundaryField()[patchID][facei]);
                                Test_Q_Vect.boundaryFieldRef()[patchID][facei].component(1) = Test_Q.boundaryFieldRef()[patchID][facei]*(mesh.Sf().boundaryField()[patchID][facei].component(1) / mesh.magSf().boundaryField()[patchID][facei]);
                        pointInterpolation.interpolate(Test_Q_Vect, pointDU);
                        const vectorField& pointDUI = pointDU.internalField();
                            vectorField newPoints = mesh.points();
                        forAll (pointDUI, pointI)
                                newPoints[pointI] += pointDUI[pointI];
I guess what I was looking for with my post is a clarification of how forAll functions in parallel and what would be considered good OpenFOAM coding practices for these loops.
In the code snippit I provided there are 3 loops
  1. First loop steps up my prescribed "Erosion"
  2. Second loop dots the scalar "erosion field Test_Q" with the surface normal vector and assigns the value to its corresponding Test_Q_Vect component
  3. takes the calculated point displacement and sums it with the current mesh.points() position in order to get the new "deformed" point field
My confusion comes in loops 1 & 2 in identifying what would be considered the "best practice".
what is the difference in looping for:
vs.
are both boundary looping methods functionally the same?
My problem is that I don't wholly understand the most effective way of coding within OpenFOAM and I'd like for this to change.
Old   October 1, 2021, 14:30
Federico Zabaleta
fedez91 is on a distinguished road
The problem is not the loop, it's the "Info<<"
"Info <<" only shows the results from processor0. If you want to output everything on every processor you should use "Pout <<"
JuRe09 likes this.
fedez91 is offline   Reply With Quote
boundary face loop, forall parallel
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
