Velocity wall function
Like Tree2Likes
  • 1 Post By mAlletto
  • 1 Post By HPE
Old   January 14, 2021, 14:59
Default Velocity wall function
René Thibault
Tibo99 is on a distinguished road
Hi everyone!
Hope you going well.
I was trying to implement a BC as a wall function for U like one shown in the picture.
I'm was trying to find something similar but I found nothing so far. Is someone here able to guide me with something, tutorial, BC template for U.
Or, is maybe better to implement a shear/gradient at the wall?
Thanks and best Regards,
Tibo99 is offline   Reply With Quote
Old   January 16, 2021, 08:13
Michael Alletto
mAlletto will become famous soon enough
https://www.openfoam.com/documentati...lFunction.html
This is quite close to what you look for I think.
I've never seen a wall function for U which implements the velocity at the wall directly. You usually compute the wall shear stress which is consistent with your assumed velocity profile. In this case a logarithmic velocity distribution over the cell adjacent to the wall
Best
Michael
Tibo99 likes this.
mAlletto is offline   Reply With Quote
Old   January 16, 2021, 16:00
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Also, have a look at https://www.openfoam.com/documentati...lFunction.html , particularly the citations where
Eqs. 6-7 in
PJ Richards and RP Hoxey. Appropriate boundary conditions for computational wind engineering models using the k-ε turbulence model. In Computational Wind Engineering 1, pages 145–153. Elsevier, 1993.
were mentioned for the implementation.
Hope it helps.
Tibo99 likes this.
HPE is offline   Reply With Quote
Old   January 18, 2021, 08:56
René Thibault
I use 'nutkAtmRoughWallFunction'' from openfoam v1906 and the results on U isn't what it should compare to the analytics solution close to the wall. Also, I noticed that the one suggested in openfoam v2006 doesn't seams exactly the same.
So, I assume that I still need to set U at the wall U = (0 0 0)?
Do you have an idea or rational explanation why the author in this case present this that way (Uw) instead of presenting it with 'nutw' or it's probably based on the authors preferences?
Thank you for replying!
Old   January 18, 2021, 09:51
René Thibault
It's work! I got the right results on the velocity.
Thank you again!
UDF for suction velocity on a wall ahmed425 Fluent UDF and Scheme Programming 0 November 2, 2017 09:50
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 02:05
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
