How can we implement a fully implicit linear source term?
Old   February 8, 2021, 21:15
Default How can we implement a fully implicit linear source term?
Rango is on a distinguished road
I would like to solve the following equation:
-\nabla.(\kappa\nabla\phi) + s = 0,
to obtain \phi field for a 3-layered simple mesh setup. Here s is a linear source term which is zero for 'upper' and 'lower' layers. For the 'mid' layer, however, we have:
s_{mid-layer}=f(\phi_{upper-layer}, \phi_{lower-layer}),
where f is a linear function.
Example: for block 3 we have: s_3=a_0\phi_1+a_1\phi_2+a_2
where a_0,a_1,a_2 are constant properties of block 3.
Is there a way to solve this equation for the whole mesh while treating the mid-layer as a buffer? Please note that the role of 'mid-layer' is nothing but coupling \phi values in 'upper-layer' and 'lower-layer' through s.
I would appreciate your help on this.
Cheers
Rango is offline   Reply With Quote
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 16:05
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
