June 25, 2021, 07:44 |
how to extract value from the previous node
#1 | |
Hello Foamers,
In my source file (.C), the following segment of code is introduced for 1D problem. Quote:
For some reason, I need to implement the above set of code once again in my customized thermo package file (similar location below). https://github.com/OpenFOAM/OpenFOAM...s/solid/thermo Here in my thermo package file, I have no idea as how to implement Equ (1) by accessing values from previous node because, there are no arguments to ‘regionMesh’ that depend on a template parameter. Kindly someone guide me out here. Thank you |
How to access the value from previous node (cell) | Kummi | OpenFOAM | 1 | July 27, 2020 11:00 |
Grid Motion Global Node Address Issue | buckngnr11 | Fluent UDF and Scheme Programming | 1 | April 24, 2020 07:44 |
Running on 4 node error MPI Errors[320798736] | tailele | STAR-CCM+ | 4 | April 2, 2020 04:59 |
Difference between mesh created from Operations node and Continua node | granzer | STAR-CCM+ | 2 | November 18, 2019 04:38 |
Host Node Allocation (-ssh and -cx) on Linux HPC | bloodflow | FLUENT | 3 | October 10, 2019 10:46 |
