how to get the unit volScalar, surfaceScalar and volVector
Like Tree1Likes
  • 1 Post By olesen
Old   July 25, 2021, 13:20
Default how to get the unit volScalar, surfaceScalar and volVector
behnamCheraghi
behnamEll is on a distinguished road
Hello every one,
I need to make a "unit phi" to get the div(phi,U)/mag(phi).
but in this case, the 1/mag(phi) may lead to a core dumped (floating point exception) error.
in fact, i try to make a surfaceScalar/volScalar/volVector such that:
if ( mag(surfaceScalar) == 0 )
surfaceScalar = 0;
else
surfaceScalar/mag(surfaceScalar);
can anyone help me?
behnamEll is offline   Reply With Quote
Old   July 25, 2021, 17:26
MNM
SHUBHAM9595 is on a distinguished road
I'm not sure what you want to achieve with "unit phi".
But to avoid FPE you can just simply add the machine epsilon in the denominator. Something like
surfaceScalarField your_Desired_var = 1/(mag(phi) + VSMALL);
where VSMALL is float having magnitude \cong 1.93e-34
SHUBHAM9595 is offline   Reply With Quote
Old   July 26, 2021, 00:50
behnamCheraghi
in fact i am looking for a property on the cell face using *upwind* schemes, but without the phi magnitude.
for example \nabla.(mdot U) without the mdot magnitude.
by adding an small values, again, there is a possibility that the values ​​will be zero. because there are negative and positive values ​​of it.
Old   July 26, 2021, 07:55
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by behnamEll View Post
Hello every one,
surfaceScalar = 0;
else
can anyone help me?
stabilise() ? Eg, x / stabilise(y, SMALL)
behnamEll likes this.
olesen is offline   Reply With Quote
unit phi, unit surfacescalar, unit volscalar, unit volvector
