July 29, 2021, 02:38 |
Multiphase flow + Heat transfer
Anonymous.
Rep Power: 5 |
Dear all,
I am trying to simulate melt pool simulation with deposition on a substrate. Currently, the code is based on OF8 and has the following. Velocity equation capturing Darcy source term for phase change and surface tension source term. Energy equation with Heat source term and latent heat source term. I tried doing a mass addition script by adding the deposition onto the substrate but the problem is that the initialized temperature is 1600k on the 1st timestep when it started deposition but subsequently it turns into 0K on 2nd timestep onwards. Does anybody know the reason behind this? |
July 29, 2021, 03:14 |
Uwe Pilz
Rep Power: 15 |
It may be that your time step is too large. It looks as if there moves more heat energy outwards the central body than it has.
There seems an extreme convection in the surrounding fluid too. Or the changes in temperature disappear in the large difference between the phases. Ther shluld be a heat flow visible in the outer phase.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
CFD simulation and heat transfer of gap flow in rectangular duct | marv91 | OpenFOAM Running, Solving & CFD | 0 | April 17, 2017 09:11 |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
Immersion Multiphase Heat Transfer | Liquid774 | FLUENT | 0 | June 4, 2012 15:37 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
multiphase flow heat transfer | yeeking86 | CFX | 1 | April 16, 2009 08:29 |
