August 1, 2021, 05:47 |
fixed temperature in porous zone
#1 | |
Alan w
Rep Power: 6 |
In a previous post regarding how to specify a temperature in a porous zone, TEMPEST answers his own question as follows. But as a relative newbie, I don't understand how to implement the TEqn.H file. Where does it go, and are there any programming changes that need to accompany it?
August 1, 2021, 07:48 |
Petros Ampatzidis
Rep Power: 7 |
All files ending in "<>Eqn.H" contain source code that defines a mathematical model that the solver will solve. All these files are included and compiled in the solver's application folder. For example, see buoyantBoussinesqSimpleFoam and the respective TEqn.H file, which you can use as a template for your own implementation. Best, Petros |
August 1, 2021, 10:00 |
Alan w
Rep Power: 6 |
Thanks Petros!
From my quick look at buoyantBoussinesqSimpleFoam, it seems like it address liquids, not air. My need is to simulate airflow through a heated porous media. Am I incorrect in my observation about the solver, or is there another more appropriate one? |
August 2, 2021, 10:39 |
Petros Ampatzidis
Rep Power: 7 |
Air is a fluid itself so it makes no difference. I don't know what you want to simulate exactly, not to mention what assumptions your case involves, but you can have a brief description of every solver if you search for solvers dedicating to heat transfer. See here for example for heat transfer solvers in v2012. |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Porous jump and Porous Zone difference | Qkarl | FLUENT | 3 | April 29, 2020 11:33 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
Error in solution using "Grid Interface" | agustinvo | FLUENT | 4 | January 20, 2015 12:03 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
