[Sponsors] | |||||
How to add Body force to a simple propeller model |
hirota tomohiro
Rep Power: 6 ![]() |
Hello everyone. What I am currently trying to do is to study the flow around the hull taking into account the rotation of the propeller. I think that calculating the propeller and hull as a single unit is very costly and unrealistic. Therefore, we are considering alternative methods. The methods we are currently considering are 1. First, we calculate the propeller alone in a uniform flow. 2. Next, together with the hull model, we will place a simple propeller model (disk shape?) in place of the complex propeller model. Instead of the complex propeller model, place a simple propeller model (disk shape?) in its original location. 3. Based on the result of step 1, a volume force is added to the simple propeller model (disk shape?). I would like to add the volume force to the simple propeller model (disk shape?) and calculate around the hull. Currently, I have completed the calculations in step 1 using both AMI and MRF methods, and I am wondering at what point to add the volume force. What methods exist for approaching this in OpenFOAM? I'm using OpenFOAM-4.x. I feel that this is a difficult problem that I cannot solve without your help. Thank you very much for your help. |
| Tags |
| ami, body-force, hull, mrf, propeller |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| interFOAM, how to define body force and force on interface | Prosper | OpenFOAM Pre-Processing | 3 | June 17, 2021 10:56 |
| How to add a body force to a momentum equation | anon_q | OpenFOAM Programming & Development | 25 | May 11, 2021 16:39 |
| Fluid Domain moving with Rigid body | Lloyd Sullivan | CFX | 3 | August 17, 2018 10:58 |
| Add Work due to body force in the energy equation for a lagrangian solver | mneben | OpenFOAM Programming & Development | 6 | January 19, 2016 06:30 |
| Force on moving body | joechorn | Fluent UDF and Scheme Programming | 5 | April 2, 2015 12:25 |
