compiling a single application in OpenFOAM
Old   October 7, 2021, 04:08
Default compiling a single application in OpenFOAM
benoit paillard
bennn is on a distinguished road
I'm trying to build a light container with only a few basic OpenFOAM solvers : simpleFoam and cartesianMesh for instance.
I understand there are heaps of dependencies here, and I'd like to keep only the bare requirements for these apps. I couldn't succeed so far, so I have a couple of questions :
- Does it make sense, and will the generated image be that much lighter than the complete build ?
- Is there an easy way to do that, some tool which would compile only the required libraries for each ?
Thank you for your help !
bennn is offline   Reply With Quote
Old   October 7, 2021, 12:01
Tobermory will become famous soon enough
Since the majority of OF is in libraries, could you not simply take the vanilla OF, make a copy, and then delete the libraries and any unused solvers and applications from the copy that you think that you might not need.
I would set up a "test suite" that you can run to check that the solvers that you are interested in work okay, and then start deleting a batch of libraries at a time, running the test suite to check that you didn't remove one that you needed. Be careful though - the suite would need to cover the full range of runtime selected models that you want to employ.
As for the first question - does it make sense. In my mind, only if you are REALLY short on disk space, and want to keep the installation size down, otherwise I don't think that you get any substantial memory savings (although I confess I know almost nothing about containers, so I could be totally wrong there).
Tobermory is offline   Reply With Quote
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer wildfire230 OpenFOAM Installation 20 May 6, 2020 07:30
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 11:52
my query on implementation of a new application on OpenFOAM Annier OpenFOAM Running, Solving & CFD 3 June 28, 2013 03:18
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
