InterFOAM+Temperature Equation + alpha update |
February 15, 2022, 21:49 |
Anonymous.
Rep Power: 5 |
Hi all, I am trying to implement my temperature equation to OpenFOAM.
I have an additional mass update that changes the cells at every timestep from gas to solid phase hence a change in density. After implementing what I think is correct, the temperature reading in the gas phase goes higher and higher until the simulation cannot solve anymore due to floating-point error, (is this what u call diverge?). Nevertheless, I would like to check with you guys if you happen to know what are things to look out for when implementing such a complex system? |
February 16, 2022, 20:45 |
Help
Anonymous.
Rep Power: 5 |
Hi Anybody knows what are the issues?
For example, I am updating forAll(alpha1,celli) { if(some condition) { alpha1[celli] = 1.0; T[celli] = 1900; } } What are the things I need to lookout for when I update the Volume fraction alpha1? |
How can temperature e treated as a passive scalar be used in transport equation? | granzer | OpenFOAM Running, Solving & CFD | 3 | June 6, 2021 16:35 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
SimpleFoam and Temperature Equation | Pat84 | OpenFOAM Running, Solving & CFD | 5 | June 16, 2014 00:43 |
about bounded alpha equation for bubbleFoam and twoPhaseEulerFoam | kaifu | OpenFOAM | 2 | May 6, 2011 05:33 |
