coded fixed value
Old   February 23, 2022, 10:06
Post coded fixed value
mfr
ucceyrekkokorec is on a distinguished road
Hi foamers,
I'm trying to simulate rotor stator interaction on a gas turbine blade. I want to take the outlet values and give to inlet by flipping the surface values. To illustrate, consider a 2D plate the value at the right bottom corner will be the left top corner value entering the inlet. I know how to read velocity or pressure values on a boundary. But how can ı flip it and write to another boundary?
ucceyrekkokorec is offline   Reply With Quote
Old   February 25, 2022, 08:41
Default outletMappedUniformInlet as an example
Bas Nieuwboer
bjnieuwboer is on a distinguished road
While I don't have the exact answer for you I can point you in a general direction. First you can have a look at all the boundary conditions openfoam has to offer:
https://www.openfoam.com/documentati...ary-conditions . I searched for mapped and came across the 'outletMappedUniformInlet' boundary condition.
The 'outletMappedUniformInlet' boundary conditions maps a flux at the outflow to the inflow. This can be used as a base case. The description of the entries can be found in the header file: https://www.openfoam.com/documentati...8H_source.html .
Some general notes on how to create a boundary condition can be found in: http://www.tfd.chalmers.se/~hani/kur...yCondition.pdf . It shows the implementation of a parabolic boundary condition. There are also youtube video's of how to implement such a boundary condition if you need inspiration.
bjnieuwboer is offline   Reply With Quote
Old   February 26, 2022, 00:55
mfr
Firstly, thank you for your response. I think ı might solve the problem by using timeVaryingMappedFixedValue. But it takes value from files. How can ı use codeStream to code what ı want as points and data.
<patch name>
type timeVaryingMappedFixedValue;
<patch name>
dataDir "../<source case name>/postProcessing/sample";
points "0/<sample name>/faceCentres";
sample <sample name>;
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Mass imbalance with fixed values (euler-euler) CeesH FLUENT 0 April 6, 2018 09:12
fixed bed reactor Many Fluent Multiphase 2 February 12, 2018 22:30
Fixed CL mode in SU2 V4.2 ygd SU2 0 November 15, 2016 10:59
codeInclude in coded function in controlDict, and yPlus LuisAlberto OpenFOAM Programming & Development 4 August 18, 2015 13:48
