Strange behaviour - custom boundary condition runs many times in 1 timestep |
March 26, 2022, 20:34 |
TWB
Rep Power: 19 |
I tried to create a boundary incoming U boundary condition to change its value at each timestep. I tried using codedFixedValue and now also high lvl programming. I tried to print some variables such as U, time for debugging purpose but I realised somethings strange - the U velocity is changed twice in 1 timestep when running simpleFoam. Moreover, if pimpleFoam is used, it runs even more -> twice within each pimpleFoam iteration. My code is Code:
inlet { type codedFixedValue; value $internalField; name u_6dof_change; code #{ scalar cur_incoming_vel; const fvPatch& boundaryPatch = patch(); vectorField& field = *this; forAll(boundaryPatch, faceI) { field[faceI] = field[faceI] + vector(1., 0,0); cur_incoming_vel = field[faceI].component(vector::X); } Info << "current incoming velocity = " << cur_incoming_vel << endl; #}; Code:
Starting time loop Time = 0.0001 current incoming velocity = 2 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 6.81739e-09, No Iterations 18 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 7.71109e-09, No Iterations 16 GAMG: Solving for p, Initial residual = 1, Final residual = 0.00713548, No Iterations 11 time step continuity errors : sum local = 2.62419e-08, global = -1.09807e-09, cumulative = -1.09807e-09 current incoming velocity = 3 current incoming velocity = 4 ExecutionTime = 0.14 s ClockTime = 0 s Time = 0.0002 smoothSolver: Solving for Ux, Initial residual = 0.478384, Final residual = 3.57783e-09, No Iterations 18 smoothSolver: Solving for Uy, Initial residual = 0.37882, Final residual = 9.38104e-09, No Iterations 16 GAMG: Solving for p, Initial residual = 0.104267, Final residual = 0.0010176, No Iterations 10 time step continuity errors : sum local = 1.40033e-07, global = -2.25939e-08, cumulative = -2.3692e-08 current incoming velocity = 5 current incoming velocity = 6 ExecutionTime = 0.17 s ClockTime = 0 s Time = 0.0003 |
May 19, 2022, 00:44 |
TWB
Rep Power: 19 |
I finally realised why this is happening. It turns that that it is due to: Code:
moveMeshOuterCorrectors yes When this is specified, this will update the mesh every single outer iteration of the PIMPLE loop (with iterative marching enabled). For moving bodies, you can use the option moveMeshOuterCorrectors yes to gain more stability. This is reported in : http://www.wolfdynamics.com/training...s_2021_OF8.pdf |
Fatal overflow in linear solver. | iamnotfajar | CFX | 9 | October 28, 2020 04:47 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
strange pressure behaviour with symmetricPlane boudary condition - interFoam | duongquaphim | OpenFOAM Running, Solving & CFD | 10 | August 20, 2013 14:00 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
