Error while compiling a solidParticle library based on interFoam in OF5x |
March 30, 2022, 04:05 |
Feng
Rep Power: 9 |
In order to simulate the movement of bubbles in fluids, I am trying to couple the solidParticle library based on the interFoam. Follow the steps of this tutorial,http://www.tfd.chalmers.se/~hani/kur...Ghahramani.pdf and compile successfully in OF3.0.0.
But when I compile the same code in the new version OF5.x, I get the following compilation error, Code:
solidParticleCloudI.H:77:79: error: no match for ‘operator=’ (operand types are ‘const Internal {aka const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>}’ and ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’) tsource().internalField() = -smom_/(mesh_.time().deltaT().value()*mesh_.V()); ^ In file included from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.H:366:0, from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvMesh.H:58, from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvCFD.H:7, from interFoam.C:40: /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:424:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::DimensionedField<Type, GeoMesh>&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh] void DimensionedField<Type, GeoMesh>::operator= ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:424:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’ to ‘const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>&’ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:445:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::tmp<Foam::DimensionedField<Type, GeoMesh> >&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh] void DimensionedField<Type, GeoMesh>::operator= ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:445:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’ to ‘const Foam::tmp<Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> >&’ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:469:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::dimensioned<Type>&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh] void DimensionedField<Type, GeoMesh>::operator= ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:469:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’ to ‘const Foam::dimensioned<Foam::Vector<double> >&’ In file included from solidParticleCloud.H:153:0, from interFoam.C:47: solidParticleCloudI.H: In member function ‘Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::solidParticleCloud::AddToU() const’: solidParticleCloudI.H:146:31: error: no match for ‘operator=’ (operand types are ‘const Internal {aka const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>}’ and ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’) Usource().internalField() = correctU_; ^~~~~~~~~ In file included from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.H:366:0, from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvMesh.H:58, from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvCFD.H:7, from interFoam.C:40: /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:424:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::DimensionedField<Type, GeoMesh>&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh] void DimensionedField<Type, GeoMesh>::operator= ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:424:6: note: no known conversion for argument 1 from ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ to ‘const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>&’ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:445:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::tmp<Foam::DimensionedField<Type, GeoMesh> >&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh] void DimensionedField<Type, GeoMesh>::operator= ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:445:6: note: no known conversion for argument 1 from ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ to ‘const Foam::tmp<Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> >&’ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:469:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::dimensioned<Type>&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh] void DimensionedField<Type, GeoMesh>::operator= ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:469:6: note: no known conversion for argument 1 from ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ to ‘const Foam::dimensioned<Foam::Vector<double> >&’ /home/fxr/OpenFOAM/OpenFOAM-5.x/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/interFoam.o' failed make: *** [Make/linux64GccDPInt64Opt/interFoam.o] Error 1 Code:
// 2Way Coupling- Momentum Source: inline tmp<volVectorField> solidParticleCloud::momentumSource() const { tmp<volVectorField> tsource ( new volVectorField ( IOobject ( "smom", mesh_.time().timeName(), mesh_, IOobject::NO_READ, IOobject::NO_WRITE ), mesh_, dimensionedVector ( "zero", dimensionSet(1, -2, -2, 0, 0), vector::zero ) ) ); tsource().internalField() = -smom_/(mesh_.time().deltaT().value()*mesh_.V()); //tsource().primitiveFieldRef() = -smom_/(mesh_.time().deltaT().value()*mesh_.V()); return tsource; } Thanks in advance |
bubble cavitation, lagrangian bubble, openfoam5.x, solidparticle |
New solver based in interFoam | claudiocor | OpenFOAM Programming & Development | 7 | December 31, 2020 21:05 |
simpleFoam with gravity, based on interFoam | JonW | OpenFOAM | 1 | May 9, 2019 10:08 |
Weird Problem while compiling new library | ashish.vinayak | OpenFOAM Programming & Development | 3 | March 15, 2019 10:39 |
dynamic mesh case based of an interFoam case | maxonline | OpenFOAM Running, Solving & CFD | 3 | February 21, 2016 14:13 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 05:58 |
