Is there an equivalent to OF Foundation's foamInfo utility in OF ESI versions? |
April 3, 2022, 09:28 |
ONESP-RO
Rep Power: 5 |
In OpenFOAM Foundation versions (openfoam6 and above) there is a utility called foamInfo. This is utility is very useful to quickly find informations about utilities, solvers, boundary conditions, etc. Here is its description: Code:
Usage: foamInfo [OPTIONS] <name> options: -all | -a list all tutorials that use <name> (otherwise maximum 10) -browser | -b <name> output C++ source guide web page with specified browser, e.g. foamInfo -browser "firefox" -help | -h print the usage -keyword | -k uses <name> as a keyword, rather than an exact match -web | -w output C++ source guide web page with the browser specified in the global controlDict file Prints the following for an application, a script, or a model (including boundary conditions, function objects and fvOptions). - File: the location of the relevant source code header file; - Description details from the header file; - Usage details from the header file; - Examples: a list of relevant cases from the tutorials directory. By default, finds a case-sensitive match to <name>; otherwise, a case-insensitive match; otherwise, looks for a broader keyword match with "-keyword | -k" option. Examples: foamInfo simpleFoam foamInfo turbulentIntensityKineticEnergyInlet foamInfo fixedTemperatureConstraint foamInfo surfaces foamInfo foamNewBC foamInfo wallFunction foamInfo kEpsilon foamInfo -k kEpsilon foamInfo fixedValue foamInfo -k fixedValue foamInfo -k contactAngle To sum up: Is there an equivalent utility similar to foamInfo for OpenFOAM ESI versions? Thank you |
wallHeatFlux Calculation wrt utility version | ahmet | OpenFOAM Post-Processing | 1 | December 18, 2016 19:45 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 16:47 |
