Interpolation Scheme on grad(U)
Like Tree1Likes
  • 1 Post By HPE
Old   April 8, 2022, 14:28
Default Interpolation Scheme on grad(U)
René Thibault
Tibo99 is on a distinguished road
Hi everyone,
Since the flow I want to simulate show that dU/dz is non-linear, I want to implement an interpolation scheme on velocity U by applying the scheme on grad(U) in the sub dictionnary 'gradSchemes', file fvSchemes.
Everything compile successfully (no message of error), but the results (U, k ,epsilon) are not what I should observe (comparing with litterature).
Does anyone see something really bad that could cause an issue in the following code that I am endup with?
FYI, I used the interpolation scheme 'localMax' as a template.
Thank you very much for the feedback.
#ifndef UInterpolationScheme_H
#define UInterpolationScheme_H
#include "surfaceInterpolationScheme.H"
#include "volFields.H"
#include "surfaceFields.H"
namespace Foam
                 Class UInterpolationScheme Declaration
template<class Type>
class UInterpolationScheme
    public surfaceInterpolationScheme<Type>
    // Private Data
    scalar z0_ = 0;
public:
    //- Runtime type information
    TypeName("UInterpolationScheme");
    // Constructors
        //- Construct from Istream.
            const fvMesh& mesh,
            Istream& is
            surfaceInterpolationScheme<Type>(mesh)
            z0_ = readScalar(is);
        //- Construct from faceFlux and Istream
            const fvMesh& mesh,
            const surfaceScalarField& faceFlux,
            Istream& is
    // Member Functions
        //- Return the interpolation weighting factors
        virtual tmp<surfaceScalarField> weights
            const GeometricField<Type, fvPatchField, volMesh>&
        ) const
            NotImplemented;
            return tmp<surfaceScalarField>(nullptr);
        //- Return the face-interpolate of the given cell field
        virtual tmp<GeometricField<Type, fvsPatchField, surfaceMesh>>
        interpolate
            const GeometricField<Type, fvPatchField, volMesh>& vf
        ) const
            const fvMesh& mesh = vf.mesh();
            tmp<GeometricField<Type, fvsPatchField, surfaceMesh>> tvff
                new GeometricField<Type, fvsPatchField, surfaceMesh>
                    IOobject
                        "UInterpolationScheme::interpolate(" + vf.name() + ')',
                        mesh.time().timeName(),
                        mesh
                    mesh,
                    vf.dimensions()
            GeometricField<Type, fvsPatchField, surfaceMesh>& vff = tvff.ref();
            // computing interpolation on the internal faces-------------------
            forAll(mesh.Cf(), facei)
                // getting owner and neighbour cell indices first
                label owner_id = mesh.faceOwner()[facei];
                label neighbour_id = mesh.faceNeighbour()[facei];
                // finding which cell is to be P and N based on height
                scalar z_owner = mesh.C()[owner_id].z();
                scalar z_neighbour = mesh.C()[neighbour_id].z();
                label P_id, N_id;
                if (z_owner < z_neighbour)
                    P_id = owner_id;
                    N_id = neighbour_id;
                else
                    N_id = owner_id;
                    P_id = neighbour_id;
                // getting Z coordinates of P and N cells & n face
                scalar Z_N = mesh.C()[N_id].z()+z0_;
                scalar Z_P = mesh.C()[P_id].z()+z0_;
                scalar Z_n = mesh.Cf()[facei].z()+z0_;
                scalar numerator = Foam::log(Z_N/Z_n);
                scalar denominator = Foam::log(Z_N/Z_P);
                scalar alphaU(1.0);
                if(numerator != 0 || denominator != 0)
                    alphaU = numerator/denominator;
                vff[facei] = alphaU*vf[P_id] + (1-alphaU)*vf[N_id];
            typename GeometricField<Type, fvsPatchField, surfaceMesh>::
                Boundary& bff = vff.boundaryFieldRef();
            forAll(bff, patchi)
                const fvPatchField<Type>& pf = vf.boundaryField()[patchi];
                Field<Type>& pff = bff[patchi];
                if (pf.coupled())
                    tmp<Field<Type>> tpif(pf.patchInternalField());
                    const Field<Type>& pif = tpif();
                    tmp<Field<Type>> tpnf(pf.patchNeighbourField());
                    const Field<Type>& pnf = tpnf();
                    forAll(pff, i)
                        pff[i] = max(pif[i], pnf[i]);
                else
                    pff = pf;
            return tvff;
    // Member Operators
} // End namespace Foam
#endif
Tibo99 is offline   Reply With Quote
Old   April 8, 2022, 17:33
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
just randomly shooting - might be the source of problems? discrepancy in fvc::grad(U)
Tibo99 likes this.
HPE is offline   Reply With Quote
Old   April 11, 2022, 10:00
René Thibault
Thank for answering,
Actually, I came across this thread some weeks ago and I was suspecting that could be the issue.
But, in the k-epsilon turbulence model, just before resolving the transport equation, we can see these lines here:
tmp<volTensorField> tgradU = fvc::grad(U);
     const volScalarField::Internal GbyNu
         this->type() + ":GbyNu",
         tgradU().v() && dev(twoSymm(tgradU().v()))
     const volScalarField::Internal G(this->GName(), nut()*GbyNu);
     tgradU.clear();
Correct me if I'm wrong, but because of what its described in the thread that you share, they add these lines to make sure that the term are the right one used in the transport equation?
Also, I performed some testing by using my new interpolation scheme files and then instead of implementing the new formula, I was using the following formula:
vff[facei] = (vf[P_id] + vf[N_id])/2;
,and then I compare the results by using 'grad(U) Gauss linear;'. I got the same results.
What is your thought?
Thanks again for answering.
Constructing Surface Interpolation Scheme from Divergence Scheme Information ngj OpenFOAM Programming & Development 2 June 17, 2022 09:12
Face pressure interpolation scheme based on linear interpolation Shibi OpenFOAM Programming & Development 8 February 14, 2022 08:20
Flux Limiter and Interpolation Scheme pablitobass OpenFOAM Programming & Development 10 December 3, 2016 13:15
Use of upwind scheme for interpolation of u/v quarkz Main CFD Forum 6 August 30, 2011 04:10
On the harmonic interpolation scheme for the diffusivity coefficient vkrastev OpenFOAM 5 April 11, 2011 09:13
