On chtMultiRegionTwoPhaseEulerFoam to develop chtMultiRegionCompressibleInterFoam |
April 13, 2022, 06:31 |
Rep Power: 4 |
Hello to all,
Following the post in compressibleInterFoam with conjugated heat transfer I started developing a chtMultiRegionCompressibleInterFoam with OFv2106 However, upon checking chtMultiRegionTwoPhaseEulerFoam I got several doubts regarding the solver. If anyone can give me hand with it, I would highly appreciate it. 1. Shound't the name of the solver be chtMultiRegionReactingTwoPhaseEulerFoam? It is solving the "YEqns". There are two solvers in ${FOAM_SOLVERS}/multiphase named twoPhaseEulerFoam. One accounts for reactions, the other does not. 2. Where is the initialMassFluid being used? It is being calculated in line 284 of createFluidFields.H Code:
initialMassFluid[i] = fvc::domainIntegrate(phaseSystemFluid[i].rho()).value(); 3. Any particular reason for compressibleInterFoam not using the pRefCell, pRefValue? And where is it being used in chtMultiRegionTwoPhaseEulerFoam ? Finally, I would like to know how to compute the Courant number for a multiRegion case where dt can is based on the Courant number and Alpha Courant number. In compressibleInterFoam, ignoring LTS, this is being calculated and defined from line 104-106 of compressibleInterFoam.C Code:
src/finiteVolume/cfdTools/incompressible/CourantNo.H scalar CoNum = 0.0; scalar meanCoNum = 0.0; { scalarField sumPhi ( fvc::surfaceSum(mag(phi))().primitiveField() ); CoNum = 0.5*gMax(sumPhi/mesh.V().field())*runTime.deltaTValue(); meanCoNum = 0.5*(gSum(sumPhi)/gSum(mesh.V().field()))*runTime.deltaTValue(); } Info<< "Courant Number mean: " << meanCoNum << " max: " << CoNum << endl; applications/solvers/multiphase/VoF/alphaCourantNo.H scalar maxAlphaCo ( runTime.controlDict().get<scalar>("maxAlphaCo") ); scalar alphaCoNum = 0.0; scalar meanAlphaCoNum = 0.0; if (mesh.nInternalFaces()) { scalarField sumPhi ( mixture.nearInterface()().primitiveField() *fvc::surfaceSum(mag(phi))().primitiveField() ); alphaCoNum = 0.5*gMax(sumPhi/mesh.V().field())*runTime.deltaTValue(); meanAlphaCoNum = 0.5*(gSum(sumPhi)/gSum(mesh.V().field()))*runTime.deltaTValue(); } Info<< "Interface Courant Number mean: " << meanAlphaCoNum << " max: " << alphaCoNum << endl; applications/solvers/multiphase/VoF/setDeltaT.H if (adjustTimeStep) { scalar maxDeltaTFact = min(maxCo/(CoNum + SMALL), maxAlphaCo/(alphaCoNum + SMALL)); scalar deltaTFact = min(min(maxDeltaTFact, 1.0 + 0.1*maxDeltaTFact), 1.2); runTime.setDeltaT ( min ( deltaTFact*runTime.deltaTValue(), maxDeltaT ) ); Info<< "deltaT = " << runTime.deltaTValue() << endl; } Code:
scalar CoNum = -GREAT; scalar alphaCoNum = -GREAT; scalar maxAlphaCo = -GREAT; forAll(fluidRegions, regionI) { scalar CoNumI = 0.0; scalarField sumPhi ( fvc::surfaceSum(mag(phiFluid[regionI]))().primitiveField() ); CoNumI = 0.5*gMax(sumPhi/fluidRegions[regionI].V().field())*runTime.deltaTValue(); CoNum = max(CoNumI, CoNum); // Calculation of alphaCourant.H from applications/solvers/multiphase/VoF/alphaCourantNo.H maxAlphaCo = max(maxAlphaCo, fluidRegions[regionI].time().controlDict().get<scalar>("maxAlphaCo")); scalar alphaCoNumI = 0.0; if (fluidRegions[regionI].nInternalFaces()) { scalarField sumPhi ( mixtureFluid[regionI].nearInterface()().primitiveField() *fvc::surfaceSum(mag(phiFluid[regionI]))().primitiveField() ); alphaCoNumI = 0.5*gMax(sumPhi/fluidRegions[regionI].V().field())*runTime.deltaTValue(); } alphaCoNum = max(alphaCoNumI, alphaCoNum); } Last edited by theBananaTrick; April 21, 2022 at 07:58. |
April 18, 2024, 19:28 |
Oscar Zagal
Rep Power: 2 |
Hello there
With respect your first question, there are no boundary conditions about species, then I don't understand why the solver solves that equation, did you find the reason? |
how to develop code that scales well without having access to supercomputers? | aerosayan | Main CFD Forum | 18 | May 21, 2022 20:33 |
How to develop OpenFOAM with CMake and popular IDEs | cosscholar | OpenFOAM Programming & Development | 0 | March 16, 2022 15:17 |
How to develop a LES interMixingFoam case | Wais | OpenFOAM Pre-Processing | 0 | April 29, 2014 22:05 |
[ICEM] can't develop good grid | anawana | ANSYS Meshing & Geometry | 0 | April 26, 2014 07:45 |
Did someone develop a CIP solver | tachioka | OpenFOAM Running, Solving & CFD | 0 | October 10, 2007 10:17 |
