Function Objects - PatchFunction1
Old   May 3, 2022, 13:05
Default Function Objects - PatchFunction1
Utkan Erdem
Utkan is on a distinguished road
Hello Foamers,
I am still new to programming in OpenFOAM, so I wanted to ask a question that may be trivial for others.
I am trying to implement a time-varying externalWallHeatFlux boundary condition to an already existing case of "hotRoom". In my case, I want to have the outer walls receive varying external heat loads with time while calculating the radiative heat transfer of different materials within the room.
I already have a .txt file (which is convertible into a .csv file) that has the external heat flux data on different columns and with each row, the time-step is incremented by one. I've learned that with patchFunction1 utility under meshTools library, it is possible to have time and space varying heat fluxes as a boundary condition and PatchFunction1 is no different than a regular Function1.
The problem is, that I cannot utilize this utility in the controlDict file. When I follow the steps on these two websites
https://www.openfoam.com/documentati...n-objects.html and https://cpp.openfoam.org/v3/a00004.html I get a fatal error saying that PatchFunction1 is an unknown function type and gives me 9 types of valid function objects.
What am I doing wrong here? Do you know how can I introduce the PatchFunction1 utility as a function object to the solver?
Thanks for reading, any help would be greatly appreciated.
Utkan is offline   Reply With Quote
Error in enabling the python wrapper Jinn SU2 Installation 2 April 23, 2022 13:52
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
