Correct way of defning thermophysicalProperties for rhoCentralFoam |
September 25, 2017, 09:59 |
Vachan Potluri
Rep Power: 8 |
I am wondering what is the correct way of defining thermophysicalProperties for rhoCentralFoam. I am using openfoam v-4.1. In the shockTube tutorial case of rhoCentralFoam, thermophysicalProperties dictionary is as shown below. Code:
// In shockTube case thermoType { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { nMoles 1; molWeight 28.96; } thermodynamics { Cp 1004.5; Hf 2.544e+06; } transport { mu 0; Pr 1; } } Code:
// In forwardStep case thermoType { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } // Note: these are the properties for a "normalised" inviscid gas // for which the speed of sound is 1 m/s at a temperature of 1K // and gamma = 7/5 mixture { specie { nMoles 1; molWeight 11640.3; } thermodynamics { Cp 2.5; Hf 0; } transport { mu 0; Pr 1; } } How will the solver detect the way these properties are defined? Or do the units not matter at all? Any help would be greatly appreciated. Thanks, Vachan |
May 13, 2022, 13:55 |
My case is diverging or giving error
Fuad Hasibul Hasan
Rep Power: 4 |
Have you found any solution to this situation? I tried to build a case using OF-2106 rhoCentralFoam/forwardStep example case. I replaced the values in U, p, T in 0/ directory with values in S.I units. But the problem either diverges or shows error as following:
1] --> FOAM FATAL ERROR: (openfoam-2012 patch=210618) [1] Maximum number of iterations exceeded: 100 when starting from T0:3.00001e-08 old T:14188.4 new T:14188.4 f:24591 p:-3.57235e-06 tol:3.00001e-12 [1] [1] From Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>] [1] in file /usr/src/packages/BUILD/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. [1] |
rhocentrafoam, thermophysicalproperties |
Is my Dynamic mesh setup correct? | cfd seeker | FLUENT | 16 | October 30, 2020 06:16 |
interFoam | Hydraulic Jump | Correct boundary condition p_rgh | pythag0ra5 | OpenFOAM Running, Solving & CFD | 17 | September 5, 2014 04:31 |
Where are correct () and update() functions defined ? | sasanghomi | OpenFOAM | 5 | August 16, 2013 09:49 |
Is there a way to find a correct "spacing"? | Jordi P. | Main CFD Forum | 2 | August 15, 2013 10:05 |
Is this understanding of turbulence models correct? | 3kha | Main CFD Forum | 3 | January 31, 2011 21:31 |
