what does kinematicCloud.SU(Uc) return?
Old   May 17, 2022, 10:37
Default what does kinematicCloud.SU(Uc) return?
Huan Zhang
Jasper Z is on a distinguished road
Dear all,
I want to know what does the momentum source function return when we call it which is defined in KinematicCloudI.H:
template<class CloudType>
 inline Foam::tmp<Foam::fvVectorMatrix>
 Foam::KinematicCloud<CloudType>::SU(volVectorField& U, bool incompressible)
 const
     if (debug)
         Pout<< "UTrans min/max = " << min(UTrans()).value() << ", "
             << max(UTrans()).value() << nl
             << "UCoeff min/max = " << min(UCoeff()).value() << ", "
             << max(UCoeff()).value() << endl;
     dimensionSet dim(dimForce);
     if (incompressible)
         dim.reset(dimForce/dimDensity);
     if (solution_.coupled())
         if (solution_.semiImplicit("U"))
             volScalarField::Internal
                 Vdt(mesh_.V()*this->db().time().deltaT());
             if (incompressible)
                 Vdt.dimensions() *= dimDensity;
             return UTrans()/Vdt - fvm::Sp(UCoeff()/Vdt, U) + UCoeff()/Vdt*U;
         else
             tmp<fvVectorMatrix> tfvm(new fvVectorMatrix(U, dim));
             fvVectorMatrix& fvm = tfvm.ref();
             fvm.source() = -UTrans()/(this->db().time().deltaT());
             return tfvm;
     return tmp<fvVectorMatrix>::New(U, dim);
If I use semiImplicit, does it return
or
I think the code returns the latter, so what does
mean?
Kind regards,
Jasper
Jasper Z is offline   Reply With Quote
No matching function error: Phase change source term added to interMixingFoam wavefunction OpenFOAM Programming & Development 2 February 4, 2022 07:46
Warning:no return statement in function returning non-void [-Wreturn-type] 3014214149 OpenFOAM Programming & Development 1 January 19, 2021 11:40
undefined reference to a C++'s class member function linyanx OpenFOAM Programming & Development 5 May 12, 2017 12:44
error adding void fraction into the solver & Error when chemistry is on cmigueis OpenFOAM Programming & Development 23 August 14, 2016 14:53
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
