Self coded 1dof pitch code differs from OF's after 1.4s |
August 2, 2022, 22:06 |
TWB
Rep Power: 19 |
I am trying to create my own 6dof code to suit my problem. I have created a 1dof y translation and it compares very similar to OF's own 6dof solver results. Now I'm trying to create a similar 1dof pitch rotation. It uses the same algorithm as OF's 6dof solver, using the newmark interpolation scheme. I found that for this case, the results (force,moment,pitch angle) are very similar up to around t=1.4s. It then starts to show some divergence between the two. I wonder why this is happening. I checked the code and it follows similar coding to the 1dof y translation, only replacing the translation with the pitching rotation. Can someone give some hints so to what could have caused the difference? Thanks. |
August 3, 2022, 03:11 |
TWB
Rep Power: 19 |
Update:
I run until around t ~ 3s. I found that there's some noticeable difference in the orientation of the airfoil. However, even at t = 3s, the difference is not big. Hence, the difference has not diverged. But at the same time instant, the velocities are different. |
How to allow MPI code run in serial mode with a single CPU core? | aerosayan | Main CFD Forum | 15 | May 30, 2022 13:05 |
Fortran->Assembly : How to remove redundant non-vectorized code? | aerosayan | Main CFD Forum | 6 | November 20, 2020 05:37 |
The different among the Pitch options | MNMK | CFX | 2 | November 12, 2020 03:27 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
