How to update surfaceScalarField boundary values in parallel cyclicBC?
Old   September 7, 2022, 04:59
Default How to update surfaceScalarField boundary values in parallel cyclicBC?
Sreehari Perumanath
sreehahaha is on a distinguished road
Dear Foamers,
I'm new to use OF and I'm developing my own solver for my problem. In it, I have to define a 'surfaceScalarField payal' and I want to give pre-calculated values to it at every time step.
To give values to the internal faces, it is simple. I give values to the boundary patch faces with:
// to loop over all boundary faces
forAll(payal.boundaryFieldRef(), patchID)
	forAll(payal.boundaryFieldRef()[patchID],facei)
   	payal.boundaryFieldRef()[patchID][facei]=<aPre-calculatedValue>;
But I use cyclicBC, so I have to do something like below for two neighbourPatches with patchIDs 0,1:
// set values on patchID=1 same as patchID=0, because cyclicBC between patches 0,1
forAll(payal.boundaryFieldRef()[1],facei)
	payal.boundaryFieldRef()[1][facei]=payal.boundaryFieldRef()[0][facei];
and likewise for other pairs of neighbourPatches (I have a very simple geometry of a cube). This works fine in a serial run. But, I imagine this would be problematic in a parallel run, as both patches may be dealt with by different processes. Can somebody please suggest an elegant way which works for both serial and parallel runs? It would be very helpful.
Many thanks and have a great day/weekend!
sreehahaha is offline   Reply With Quote
boundary patch, cyclic boundary condition, parallel code, surfacescalarfield, version 6
Update Pressure values for unsteady, multiphase, parallel - not updating properly dhaya400 Fluent UDF and Scheme Programming 6 June 7, 2021 01:43
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
parallel code samiam1000 SU2 3 March 25, 2013 04:55
