How to add multicomponent equations to the steady incompressible solver? |
January 17, 2023, 08:31 |
Rep Power: 4 |
At present, I encounter difficulties, that is, I need to establish a steady-state multi-component incompressible buoyancy solver.
There are only two basic solvers related to it, one is buoyantBoussinesqSimpleFoam, and now it is only necessary to add multiple components to it, but my many attempts have failed, and there is no solution yet. The other is rhoReactingBuoyantFoam, which needs to turn off the reaction switch, then change the transient state into the steady state and the compressible state into the incompressible state. In the process of modification, many problems were found that satisfactory results could not be achieved. So what ideas or solutions do I ask you for help now? Thank you all and wish all the best! |
January 17, 2023, 09:10 |
1/ force transient to act as steady state by using Euler with fixed time step?
2/ force compressible to act as incompressible by using rhoThermo and other suitable thermodynamics settings? |
January 19, 2023, 04:40 |
Rep Power: 4 |
hi,dlahaye
I am very grateful for the opinions of my predecessors, which has helped me. I want to use Boussinesq's method to modify the compressible into incompressible, but there is no result at present. I will try as many times as you suggest about transient and steady-state problems. |
add multicompenent |
[GUIDE] Switching from incompressible to compressible simulation | gabrielfelix | OpenFOAM Running, Solving & CFD | 2 | September 3, 2021 12:45 |
laplacianFoam - solver settings for steady state diffusion problems | Adam_K | OpenFOAM Running, Solving & CFD | 5 | June 8, 2021 14:33 |
Is it possible to add massless particles to an incompressible flow at solver level? | LauraSumner | OpenFOAM Running, Solving & CFD | 1 | September 30, 2019 17:13 |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 06:12 |
accelarate simulation using steady state solver | tjliang | OpenFOAM Running, Solving & CFD | 0 | October 7, 2016 14:42 |
