Code parallelization using Pstream: simultaneous send/receive deadlocking
Like Tree2Likes
  • 2 Post By wyldckat
Old   July 9, 2012, 06:14
Question Code parallelization using Pstream: simultaneous send/receive deadlocking
Tomislav Maric
tomislav_maric is on a distinguished road
Hi everyone,
I am trying to write the simplest parallel code that involves simultaneous communication accross processes:
Proc1: Send(0),Receive(0)
Proc2: Send(1),Receive(1)
Of course, such code will experience a deadlock. There are multiple solutions for this beginner problem: exchanging the order of Send/Receive based on the process rank, using non-blocking communication, using buffered communication (bSend, bRecv), etc.
Both the problem and possible solutions are explained here (Note: if the links don't work by clicking, copy/paste them):
http://www.ncsa.illinois.edu/UserInf...IDeadlock.html
and here:
http://www.cs.ucsb.edu/~hnielsen/cs140/mpi-deadlocks.html
So. I have tried to use these solutions in OpenFOAM, sending/receiving a scalarField around, and I keep getting errors. I linked the application source below, where you can uncomment parts of the code to get specific solutions (described in the links above). What I find strange is:
  • the code deadlocks when I properly combine blocking send/receive and receive/send
  • the code experiences FoamFatalError when I use nonBlocking communication: UPstream::waitRequests() is an empty function, Pstream::nRequests() returns 0 regardless of the number of outstanding nonBlocking requests in the program
I am not sure if I am missing something obvious, but it seems strange that every option I try, fails.
Also: I've switched on the Pstream debugSwitch in etc/controlDict, but I still don't see the debug info comming from the UPstream.C in the Pstream/mpi folder. This looks like my application is using the dummy implementation of UPstream and its children, instead of linking with stuff from Pstream/mpi.
Download link (OpenFOAM 2.0.x):
http://dl.dropbox.com/u/3316983/pStr...leExchange.tgz
Tomislav
tomislav_maric is offline   Reply With Quote
Old   July 13, 2012, 04:47
Tomislav Maric
(bump)
O.K. , let me rephrase the question: there are two processes available.
How do I use Pstream to exchange the number Pstream::myProcNo() between the processes without deadlocking?
Old   July 13, 2012, 05:14
Retired Super Moderator
Bruno Santos
Greetings Tomislav,
Have you looked at the source code for the OpenFOAM application Test-parallel? It's located at "applications/test/parallel".
It's a very decent example of what you seem to be trying to do!
Browse the other applications in the test folder as well, because I remember there are other very sweet examples of parallel manipulations!
Good luck!
Bruno
tomislav_maric and scleakey like this.
Old   July 13, 2012, 05:16
Tomislav Maric
Thanks, I'm on it!
Old   July 13, 2012, 05:20
akidess's Avatar
Anton Kidess
What went wrong with the ucsb solution? It seems brilliantly simple...
if (rank % 2) {
    MPI_Send(data, (rank + 1) % size);
    MPI_Recv(newdata, (rank - 1) % size);
} else {
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   July 13, 2012, 05:22
Tomislav Maric
if (rank % 2) {
} else {
Well, when you try this with Pstream, the thing just hangs in the air... If you don't believe me, uncomment SOLUTION 0 in the source I linked below... it's just weird.
Added: I wrote it for just 2 processes: 0 is sending/receiving to/from 1, and 1 is sending/receiving to/from 0.
Old   April 8, 2023, 09:06
Karl Sturm
sturmk is on a distinguished road
Sorry to dig this post up one decade later, but the problem still persists today (OpenFoam v9).
I hope this reaches some of the OF devs by bringing it up again...
sturmk is offline   Reply With Quote
Old   April 8, 2023, 10:26
Karl Sturm
Since the abovementioned might be a roadblocker, here's a workaround:
if(isPrimaryNode()) {
     IPstream *recv = new IPstream(Pstream::commsTypes::blocking,
                                                   secondaryNodeNo());
     *recv >> remote_data;
     delete recv;
     OPstream *send = new OPstream(Pstream::commsTypes::blocking,
                                                   secondaryNodeNo());
     *send << local_data;
     delete send;
if(isSecondaryNode()) {
                                                   primaryNodeNo());
     delete send;
                                                   primaryNodeNo());
     delete recv;
FYI: I also tried to implement a "proper" solution by allocating a separate communicator and using Pstream::exchange(). Unfortunately, UPstream::allocateCommunicator() is the bad call and blocks indefinitely.
Old   April 14, 2023, 04:31
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
If it is contiguous data, and you know the dimensions, a combination of non-blocking UIPstream::read and UOPstream::write, followed by a UPstream::waitRequests should work.
If you have non-contiguous data and want a whatever to whatever type of exchange. consider using PstreamBuffers. Setup all of your sends on primary/secondary node, mark the sends as finished and then followup with the receives. It is slight overkill since it will use the personalised exchange (involving an all-to-all for distributing sizes) but if not called within a tight loop and with fewer than say 8k ranks, should be OK.
olesen is offline   Reply With Quote
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 00:18
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 14:34
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 10:20
