Calculating distance betwee particles and air-water interfaces (bubbles) |
July 5, 2023, 15:08 |
Vivekananda
Rep Power: 9 |
Hello all,
I am trying to implement a hydrophobic force in a coupled solver of multiphaseEulerFoam and basic kinematicColliding cloud ( I have coupled multiphaseEulerFoam and basickinematic colliding cloud). Now according to literature, there exist a relation between hydrophobic force and a separation distance between the bubble and particle (H) as given below: Fh=KRp exp(-H/lambda)nhat Where Fh is the hydrophobic force, Rp is particle dia, H is the particle bubble distance , lambda is the decay length and nhat is the unit vector. Now, in order to calculate Fh, the particle bubble distance (H) needs to be calculated. In the simulation there are thousands of particles moving in random directions along with dynamically evolving bubbles. In multiphase flow we specify the bubbles by the interface where 0<alpha<1, alpha being the volume fraction. Now, is there any way to track the distance bewteen the particles and the interface to implement the hydrophobic force? Anu help would be appreciated. Regards Vivek |
eulerian-lagrangiansolver, lagrangian particle, multiphaseeulerfaom |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 21:36 |
Need suggestions about technical difficulties - Drying + Pyrolysis of coal particle | Kummi | OpenFOAM Running, Solving & CFD | 12 | April 26, 2022 13:24 |
MultiphaseEulerFoam in OpenFOAMv9 - problems with small particles | flowgeek | OpenFOAM Running, Solving & CFD | 5 | January 19, 2022 07:00 |
Simulation crashes when turbulence is on (reactingMultiphaseEulerFoam) | remidemol | OpenFOAM Running, Solving & CFD | 3 | May 26, 2020 05:47 |
Water Sphere reacting to flow of air modelling | Jacee | FLUENT | 0 | May 25, 2018 09:29 |
