Defining a Matrix in OpenFOAM-1.6-ext
Like Tree8Likes
  • 3 Post By wyldckat
  • 4 Post By Daniel_Khazaei
  • 1 Post By wyldckat
Old   October 21, 2013, 11:33
Default Defining a Matrix in OpenFOAM-1.6-ext
Daniel
Daniel_Khazaei will become famous soon enough
Hello foamers
I am trying to define a Matrix in my OpenFOAM solver but I have a few problems.
I try to describe my problem with an example:
Assuming I want to define a Matrix in the solver, this is what I do:
Matrix<scalar> A(n, m, 0.0);
Now when I want to compile the solver, it gives me the following error:
setInterfaceDisplacement.H:98: error: wrong number of template arguments (1, should be 2)
/opt/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/Matrix.H:54: error: provided for ‘template<class Form, class Type> class Foam::Matrix’
I can understand that I need to add one more argument in declaration, but I don't know what does "class Form" mean?
regards
Daniel_Khazaei is offline   Reply With Quote
Old   November 26, 2013, 10:45
Camille Bilger
kmou is on a distinguished road
I am encountering the same problem and would be grateful if you could share how you resolved this problem. Thank you very much.
kmou is offline   Reply With Quote
Old   November 26, 2013, 17:11
Retired Super Moderator
Bruno Santos
Greetings to all!
Actually, while I was tracking kmou's posts, this previous thread gave the hint: http://www.cfd-online.com/Forums/ope...t-compile.html
The solution seems to be to use "scalarSquareMatrix" instead of "Matrix<scalar>".
A bit more explanation:
  1. The definition of "scalarSquareMatrix" is made in the file "src/OpenFOAM/matrices/scalarMatrices/scalarSquareMatrix.H", where it defines the class based on the "SquareMatrix" template:
    class scalarSquareMatrix
        public SquareMatrix<scalar>
  2. The template class "SquareMatrix" is defined in the file "src/OpenFOAM/matrices/SquareMatrix/SquareMatrix.H", as follows:
    template<class Type>
    class SquareMatrix
        public Matrix<SquareMatrix<Type>, Type>
    Namely, said "class Form" is "SquareMatrix<Type>" in this case... pretty confusing template voodoo, isn't it?
Either way, the quick solution is indicated in the post #3 at the aforementioned thread .
Best regards,
Bruno
Old   November 27, 2013, 11:46
Daniel
thanks for the suggestion...
I had resolved that issue a few weeks ago. I have changed the declaration as follow:
Matrix <scalarField,scalar> A (n,m)
squareScalarMatrix is working fine on square matrices but how can I define a matrix with one column or one row?
like this one:
Matrix <scalarField,scalar> A (n,1) or A (1,n)
OK I have fixed the last one by using rectangular matrix
Old   November 27, 2013, 13:26
Daniel
Originally Posted by kmou View Post
you need to add the following headers to your program:
#include "scalarSquareMatrix.H" --->> for square type matrix
if you want to define a square matrix: A (n,n) and initiate it with 0
scalarSquareMatrix A(n, 0.0);
#include "RectangularMatrix.H" ---->> for rectangular matrix
if you want to define a rectangular matrix: A (n,m)
RectangularMatrix <scalar> A(n,m);
Old   December 2, 2013, 05:06
Camille Bilger
Thank you Daniel and Bruno for your replies.
So new classes of matrices have been created, such as SquareMatrix and RectangularMatrix, which effectively correspond do the "Form" that is required. Thus, for each Matrix<scalar> that I have, I will need to make a decision as to if it is a Square matrix, or a Rectangular matrix or Diagonal matrix etc...
Old   March 23, 2016, 10:19
Angry Matrix with different dimensions for different elements (kg,m,N,etc)
Muhammad Usman
13msmemusman is on a distinguished road
Hi guys i have a problem related to matrices. I have to define and write a matrix in which every element have different dimensions. for example 1st element has dimensions in kilogram 2nd in meters 3rd in second like that. Please guide me how can i do that.
13msmemusman is offline   Reply With Quote
Old   March 26, 2016, 06:41
Bruno Santos
Quick answer: AFAIK, that's not possible. You should not include the dimensions in the matrix and instead you should only use the values.
13msmemusman likes this.
Old   March 27, 2016, 01:50
Muhammad Usman
Thank you. but there should be a way...... coz..........
Old   March 27, 2016, 06:27
Bruno Santos
If you had provided an example I could have worked with, it would have be easier/faster for me to figure it out.
Anyway, this is an example of how to do it:
    SquareMatrix<dimensionedScalar> hmm(3);
    hmm[0][0].dimensions().reset(dimLength);
    hmm[0][0] = dimensionedScalar("cookie1",dimLength,-3.0);
    hmm[0][1] = 10.0;
    hmm[0][2] = -4.0;
    hmm[1][0] = 2.0;
    hmm[1][1] = 3.0;
    hmm[1][2] = 10.0;
    hmm[2][0] = 2.0;
    hmm[2][1] = 6.0;
    hmm[2][2] = 1.0;
It's based on the test application "applications/test/Matrix" and it took me a while to figure out the details.
Old   March 27, 2016, 06:54
Muhammad Usman
Screenshot from 2016-03-23 23:45:51.png
Please have a look on this file attached.
Old   March 27, 2016, 09:34
Bruno Santos
Quick questions:
  1. What is the calculation you're trying to perform?
    • I ask this because this matrix has to be multiplied by something!?
  2. How exactly is this matrix meant to be used?
Old   March 27, 2016, 09:42
Muhammad Usman
its matrix for mass in mass damper spring system. actually i am working with some kind of fluid and vehicle dynamics interface. Yes this matrix is gonna be multiplied by a vector
Old   March 27, 2016, 10:04
Bruno Santos
Hi Muhammad,
I don't know if you've noticed, but if you keep giving vague descriptions, then I'm only able to give vague answers as well
There is a thread explaining how to provide information, so that this kind of vague exchange of information doesn't happen: http://www.cfd-online.com/Forums/ope...-get-help.html
Best regards,
Bruno
Old   April 16, 2016, 20:55
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
It is not possible in the present versions of FOAM.
Regards!
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
Last edited by wyldckat; April 17, 2016 at 10:28. Reason: added quote, because this post was moved from another thread with the same question
santiagomarquezd is offline   Reply With Quote
Old   March 11, 2020, 07:58
Peng Liang
tjliang is on a distinguished road
Hello Everyone,
my problem is a litle bit related to the Matrix problem. I want to have one field value obtained from a two-dimensional lookup table, which means the value is dependent on two variables. Is it possible that I insert values into the Matrix and look up and interpolate among them? I know it may be quite wrong, any hints from you will be appreciated by me. Thank you.
Best regards,
Peng
tjliang is offline   Reply With Quote
Old   December 11, 2023, 14:44
Default I want to multiply two matrices E and F to obtain G so G = E*F.
  #17
Klaus
klausb will become famous soon enough
I want to multiply two matrices E and F to obtain G so G = E*F. I tried the following, I don't get compile errors but from the line //Compute G = E * F onwards, things don't work. Here's my code:
    // Set the size of the matrices
    const label N = 4; // matrix size
    // Declare and initialize lduMatrices E, F, and G
    RectangularMatrix <scalar> E(N,N);
    RectangularMatrix <scalar> F(N,N);
    RectangularMatrix <scalar> G(N,N);
    // Set coefficients for matrix E diagonal
    scalar diagonalValuesE[] = {1.0, 2.0, 3.0, 4.0};
    for (label i = 0; i < N; ++i)
        E[i][i] = diagonalValuesE[i];
    // Set coefficients for matrix F diagonal
    scalar diagonalValuesF[] = {5.0, 6.0, 7.0, 8.0};
        F[i][i] = diagonalValuesF[i];
    //Compute G = E * F
     G=E*F; // THIS DOESN'T WORK I THINK, THERE IS A FUNCTION CALLED
                 //"multiply", too but I don't know how to use it
    // Print the diagonal element G[0][0]
     Info << "Diagonal element G[0][0]: " << G[0][0] << endl;
Regarding "multiply" see: // https://www.openfoam.com/documentati...trices_8H.html
Can someone tell me how to multiply two matrices?
klausb is offline   Reply With Quote
Solver Compiling error - OF 1.6 ext. raditz OpenFOAM Programming & Development 8 November 4, 2012 09:53
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results Arnoldinho OpenFOAM Community Contributions 7 December 9, 2010 16:29
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 21:47
