Adding Temperature field to IcoFoam
Like Tree2Likes
  • 1 Post By gwierink
  • 1 Post By afeworkimussie
Old   August 3, 2009, 20:39
Default Adding Temperature field to IcoFoam
Ramesh Yapalparvi
yapalparvi is on a distinguished road
I followed this tutorial on the wiki page
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
I ran my_icoFoam
and it gave me this message
FOAM Warning :
From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s)
in file /home/ramesh/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 252
Reading "/home/ramesh/OpenFOAM/ramesh-1.5/run/my_icoFoam_cavity/0/T::movingWall" from line 25 to line 26
expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
--> FOAM Warning :
Reading "/home/ramesh/OpenFOAM/ramesh-1.5/run/my_icoFoam_cavity/0/T::fixedWalls" from line 31 to line 32
Starting time loop
Time = 0.005
Courant Number mean: 0 max: 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.96338e-06, No Iterations 8
DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 7.55402e-07, No Iterations 35
time step continuity errors : sum local = 5.03809e-09, global = 1.94884e-19, cumulative = 1.94884e-19
DICPCG: Solving for p, Initial residual = 0.523591, Final residual = 9.72352e-07, No Iterations 34
time step continuity errors : sum local = 1.07766e-08, global = 4.49324e-19, cumulative = 6.44208e-19
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type fixedvalue)
on patch movingWall of field T in file "/home/ramesh/OpenFOAM/ramesh-1.5/run/my_icoFoam_cavity/0/T"
You are probably trying to solve for a field with a generic boundary condition.
From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 692.
FOAM exiting
any help would be appreciated. Thanks
Ramesh
yapalparvi is offline   Reply With Quote
Old   August 3, 2009, 21:01
Sandy Lee
sandy is on a distinguished road
Yes, I guess my supervisor will also push me to do similar works in the next step ...
sandy is offline   Reply With Quote
Old   August 3, 2009, 22:02
Ramesh Yapalparvi
Thanks!. I have fixed the bug......
Ramesh
Old   February 16, 2010, 15:15
Nishant
nishant_hull is on a distinguished road
how did you fix the bug mate? I am also having similar bug when i tried a different boundary condition say parabolicVelocityInlet.
nishant_hull is offline   Reply With Quote
Old   February 25, 2010, 11:06
Ramesh Yapalparvi
Can you please be more specific?. Share your code so that I can have a look
Old   March 1, 2010, 21:06
Michael Jaworski
mike_jaworski is on a distinguished road
The tutorial listings lacked the keyword "uniform" from the definition of the value in the boundary conditions.
The wiki's been edited to fix this - but the information is contained in the "warning" messages that were posted.
-Mike
mike_jaworski is offline   Reply With Quote
Old   April 7, 2010, 07:37
Javed
Javed is on a distinguished road
Hi friends,
I am facing sm pbm while compiling my own icoFOAM solver using wmake command..I m getting following pbm
javed@javed:~/OpenFOAM-RUN/OpenFOAM-1.6/applications/solvers/incompressible/icoFoam_temp$ wmake
make: *** No rule to make target `icoFoam.dep', needed by `Make/linuxGccDPOpt/dependencies'. Stop.
Please help me out.
Javed is offline   Reply With Quote
Old   April 7, 2010, 09:09
Nishant
Always use wclean before wmake. Or make sure there is no .dep file while doing wmake.
Nishant
Old   April 7, 2010, 13:46
Javed
Thanks Nishant for the quick reply..
Now after doing all the changes as per given in http://openfoamwiki.net/index.php/How_to_add_temperature_to_icoFoam, I am not able to run it as follow...plz help friends...As i m running
javed@javed:~/OpenFOAM-RUN/OpenFOAM-1.6/tutorials/incompressible/icoFoam/mycavity$ myicoFoam
Case : /home/javed/OpenFOAM-RUN/OpenFOAM-1.6/tutorials/incompressible/icoFoam/mycavity
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
// using new solver syntax:
p
solver PCG;
preconditioner
type DIC;
minIter 0;
maxIter 2000;
tolerance 1e-06;
relTol 0;
T
solver PBiCG;
preconditioner DILU;
tolerance 1e-07;
relTol 0;
U
solver PBiCG;
preconditioner
type DILU;
minIter 0;
maxIter 500;
tolerance 1e-05;
relTol 0;
Reading transportProperties
Reading field p
Reading field U
Reading field T
Starting time loop
Time = 0.005
keyword preconditioner is undefined in dictionary ":reconditioner"
file: :reconditioner from line 47 to line 47.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 388.
FOAM exiting
Plz help...
Thanks
Old   April 7, 2010, 16:37
Nishant
As far as I can see, there is some mismatch in the format of the other fields and Temperature field. Change that and see if it works.
But If you dont get it right after that, then post the line 47 (lets make it line: 40-50) of the asked file here.
regards,
Nishant
Old   April 8, 2010, 02:47
Gijsbert Wierink
gwierink is on a distinguished road
Hi Javed,
Hmm, I think system/fvSolution should look something like this:
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
    // GW Add a solver for T
    T
        solver          BICCG;
        preconditioner  DILU; //GW or: none, GAMG, diagonal
        tolerance       1e-7;
        relTol          0;
    U
        solver          PBiCG;
        tolerance       1e-05;
        relTol          0;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
vanq likes this.
Regards, Gijs
gwierink is offline   Reply With Quote
Old   March 1, 2013, 09:27
Mussie
afeworkimussie is on a distinguished road
nProcs : 1
Create time
p
solver PCG;
preconditioner
type DIC;
minIter 0;
maxIter 2000;
tolerance 1e-06;
relTol 0;
T
solver PBiCG;
tolerance 1e-07;
relTol 0;
U
solver PBiCG;
preconditioner
type DILU;
minIter 0;
maxIter 500;
tolerance 1e-05;
relTol 0;
Reading field p
Reading field U
Reading field T
Starting time loop
Time = 0.005
FOAM exiting
Plz help...
Thanks
Hi
p
solver PCG;
preconditioner DIC;
minIter 0;
maxIter 2000;
tolerance 1e-06;
relTol 0;
This sort of presenting the fvSolution will solve the problem
vanq likes this.
afeworkimussie is offline   Reply With Quote
Old   January 18, 2014, 06:59
Umut
Umut is on a distinguished road
I need to add energy equation to simpleFoam. There are some threads about it but they all used laminar model. Is there any model for turbulent, steady, incompressible (official or non) flow solver? Can you give me some hints?
Kind regards
Umut
Umut is offline   Reply With Quote
Old   January 18, 2014, 08:25
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
buoyantBoussinesqSimpleFoam
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   November 19, 2015, 04:57
Muhammad Usman
msman is on a distinguished road
Hi, Ramesh
I have also getting the following error while adding temperature filed to my icoFoam solver.
Actually I am trying to use icoFoam solver for lagrangian particle tracking algorithm. when i run my model without adding temperature field, it works but when i add temperature filed, it doesn`t work
usman@hyazinth:~/OpenFOAM/usman-2.3.x/applications/solvers/colloidalFoam_T> wmake
Making dependency list for source file colloidalFoam.C
SOURCE=colloidalFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/lagrangian/colloidalParticle/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/lagrangian/basic/lnInclude -I../colloidalParticle/lnInclude -IlnInclude -I. -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/colloidalFoam.o
colloidalFoam.C: In function ‘int main(int, char**)’:
colloidalFoam.C:110:9: error: no matching function for call to ‘Foam::fvMatrix<double>::fvMatrix(Foam::tmp<Foam:: fvMatrix<Foam::Vector<double> > >)’
colloidalFoam.C:110:9: note: candidates are:
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = double]
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: candidate expects 2 arguments, 1 provided
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = double]
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::tmp<Foam::fvMatrix<double> >&’
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = double]
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::fvMatrix<double>&’
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = double]
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: candidate expects 2 arguments, 1 provided
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’ [-Wunused-variable]
/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’ [-Wunused-variable]
make: *** [Make/linux64GccDPOpt/colloidalFoam.o] Error 1
msman is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
transient temperature field with constant velocity Törnquist CFX 0 September 16, 2003 04:22
Question concering about validating Temperature field ghlee Main CFD Forum 1 December 1, 1998 12:36
