1.5 => 1.6: Matrix template - ODETest does not compile
Old   October 14, 2009, 05:08
Default 1.5 => 1.6: Matrix template - ODETest does not compile
Mark Couwenberg
markc is on a distinguished road
Hello All,
with the change from version OF1.5 to 1.6, I encountered a problem when using code bits which I derived from ODETest (applications-test).
In OF 1.5 I was able to wmake ODETest without any problems. Doing this in 1.6 I get the following error message:
ODETest.C:72: error: wrong number of template arguments (1, should be 2)
OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Matrix.H:55: error: provided for ‘template<classForm, class Type> class Foam::Matrix’
ODETest.C: In member function ‘void testODE::jacobian(Foam::scalar, const Foam::scalarField&, Foam::scalarField&, int&) const’:
This error message seems clear enough. In Matrix.H I see there is a declaration of Form (Matrix<Form, type>). However I do not know how to modify the code in order to make it work again for 1.6. Any help is greatly appreciated here.
Brgds,
Mark
markc is offline   Reply With Quote
Old   November 26, 2013, 10:41
Camille Bilger
kmou is on a distinguished road
Hi markc,
I have exactly the same issue and would be grateful if you could share how you resolved this problem. Thank you very much.
kmou is offline   Reply With Quote
Old   November 26, 2013, 17:00
Retired Super Moderator
Bruno Santos
Quick answer - Mark's original issue was solved here: http://repo.or.cz/w/OpenFOAM-1.6.x.g...1b95655#patch6
Change in triangle::intersection breaks stitchMesh in 1.5 and 1.6 gschaider OpenFOAM Bugs 7 February 12, 2010 09:21
ChtMuliRegionFoam-Case (OF 1.6 Tutorial-case -> OF 1.5) suitup OpenFOAM 15 November 11, 2009 12:43
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 21:47
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
