do_while loop for coupling two equations (convergence criteria?)
Old   February 26, 2011, 11:32
Default do_while loop for coupling two equations (convergence criteria?)
Muhammad reza hassani
mhassani is on a distinguished road
hi
I have a question regarding coupling two scalar transport equations. the equations are coupled through their source term.
from the programmer's guide, source term can explicitly be added to the equation: solve(fvm::laplacian(phi) == f), f being a vol<type>Field.
I want to solve them sequentially and constructing a loop to reach to converge iteratively. in order to see the convergence, I have one problem, how I can save the previous iteration result and subtract them to see if it meets the convergence tolerance.
do{
solve(equation of C1, with a source term of C2)
solve (equation of C2, with a source term of C1)
error1=C1(n-1)-C1; //n-1 represent previous iteration results
error2=C2(n-1)-C2;//n-1 represent previous iteration results
}while(error1<0.001 && error2<0.001) //0.001 is the convergence tolerance
if you can help me, it means a lot. thanks in forward.
p.s. I have declare the errors as volScalarField and I don't know is it ok, and I have faced errors using declaration of this errors and using relational operators (>=). any suggestion?
mhassani is offline   Reply With Quote
Old   February 28, 2011, 07:56
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Muhammad, error1 and error2 will be fields and comparing them with scalar is inappropriate, I think. May be you can take the average of error1 and errors absolute values in order to have only on scalar, then compare it with your error criterion.
volScalarField C1nminus1=C1;
error1=Foam::average(Foam::mag(C1nminus1-C1)); //n-1 represent previous iteration results
Or something like this.
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   February 28, 2011, 11:13
akidess's Avatar
Anton Kidess
Why not use the residual as done in simpleFoam? Something like:
    eqnResidual = solve
        CEqn()
    ).initialResidual();
    maxResidual = max(eqnResidual, maxResidual);
Edit: Thinking about it a bit more this might just give r = Ax - b, which wouldn't really help you.
Last edited by akidess; February 28, 2011 at 11:17. Reason: Probably won't work after all, sorry
Old   February 28, 2011, 11:35
Yes, I thought in the same thing, but it supposes you're judging convergence based on residuals. Which I can understand at all is the purpose of this loop, Is this a sort of outer loop in order to better couple the solution in each time-step?
Regards.
Research Scientist
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 12:44
Convergence Criteria edwin FLUENT 1 February 14, 2008 19:24
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
convergence of Euler Equations with WENO Shyam Main CFD Forum 0 June 1, 2007 00:47
