wmake files and options details
Like Tree1Likes
  • 1 Post By abilash
Old   November 23, 2011, 11:13
Default wmake files and options details
Rui Vizinho de Oliveira
RuiVO is on a distinguished road
Good day to you all,
I'm a noobish OF user, and I wish to know where i can find detailed information regarding the meaning of the entries in the following files inside a Make folder:
files
options
Example files:
mykOmegaSST.C
LIB = $(FOAM_USER_LIBBIN)/libmyIncompressibleRASModels
I know that the first line states the program to be compiled. The second line is amazing because it has (FOAM_USER_LIBBIN) and i have seen ((FOAM_APPBIN).
Example options:
EXE_INC = \
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude
LIB_LIBS =
or another options file:
EXE_INC = \
-I./combustionModels/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
-I$(LIB_SRC)/turbulenceModels/compressible/turbulenceModel \
-I$(LIB_SRC)/thermophysicalModels/radiation/lnInclude
EXE_LIBS = \
-lcombustionModels \
-lspecie \
-lreactionThermophysicalModels \
-lbasicThermophysicalModels \
-lfiniteVolume \
-lcompressibleLESModels \
-lcompressibleRASModels \
-lradiation
Why is there a diference between the two files? One with LIB_LIBS and the other with EXE_LIBS. What is the meaning of this?
I don't expect all of this questions to be answered, I just wanted to have some good documentation on this besides the OpenFoam link:
http://www.openfoam.com/docs/user/co...plications.php
I want to be able to understand what am I doing when I want to compile something to be run as an user application of user lib ( if there is such thing as a user lib .. i don't know). I want to know if i can include a lib or app made by me as an (FOAM_APPBIN ou FOAM_LIBBIN) or something of the sort.
Best regards
Rui
RuiVO is offline   Reply With Quote
Old   November 23, 2011, 12:26
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hi Rui,
From the page you reference, this is all explained quite well; the first paragraph in 3.2.1, and all of sections 3.2.2.1 and 3.2.2.2 in particular will answer your questions. Briefly, you are compiling a library, which is why the location of the executable is different (compiled applications and libraries are each stored in specific places). The formatting of the options file is to specify where the header and object files are for compiling and linking.
mturcios777 is offline   Reply With Quote
Old   November 30, 2011, 09:35
Bernhard Linseisen
Linse is on a distinguished road
Concerning this second line:
If it is something with APPBIN it is an APPlication, with LIBBIN it is a LIBrary.
In case it says something like FOAM_APPBIN that means it is in the basic directory for OpenFOAM applications. With FOAM_USER_APPBIN it is in the directory reserved for applications made by the user. The same principle is true for libraries.
It is advisable to use the "USER"-locations, as this way you will not damage any part of the standard installation of OpenFOAM.
In case you use the same solver name for the selfmade one as for the standard one, I read that the selfmade one will be chosen by OpenFOAM. In any case it is advisable to change the name of the own solver or library, so you can distinguish between new and old implementations...
Linse is offline   Reply With Quote
Old   December 1, 2011, 10:47
akidess's Avatar
Anton Kidess
To add to the previous answers, here's a list of environment variables that can be used:
http://openfoamwiki.net/index.php/Environment_variables
Old   December 1, 2011, 16:14
Thank you all soo much !
Best regards
Rui
Old   December 24, 2017, 00:31
Ali Noaman Ibrahim
alinuman15 is on a distinguished road
files
options
Example files:
mykOmegaSST.C
Example options:
EXE_INC = \
LIB_LIBS =
EXE_INC = \
EXE_LIBS = \
-lspecie \
-lfiniteVolume \
-lradiation
Best regards
Rui
Hi Rui:-
The link http://www.openfoam.com/docs/user/co...plications.php is not available anymore, could you find the replacement?
Thanks!
alinuman15 is offline   Reply With Quote
Old   January 3, 2018, 13:38
Abilash Ananthula
abilash is on a distinguished road
https://cfd.direct/openfoam/user-gui...-applications/
abilash is offline   Reply With Quote
Old   January 3, 2018, 13:40
Abilash Ananthula
The documentation for compilation of applications is here,
silvino likes this.
Old   January 3, 2018, 13:54
Ali Noaman Ibrahim
Thanks Ailash.
I just wanted to have it on the same www.openfoam.com website as a completion to the fabulous materials available on that website.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Remeshing with User Defined Options ChristianF CFX 2 September 24, 2014 09:19
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Writing geometry files in STAR-CD Sachin Siemens 5 April 22, 2008 16:38
