outflow boundar condition problem, mutiphase flow |
April 29, 2012, 14:11 |
Mieszko Młody
Rep Power: 17 |
I am doing some multiphase flow computations using twoLiquidMixigFoam solver. Simulation (see attached figure: computational_domain.jpg calculates flow with inflow (emergency valves inflow of the fluid1 to the tunnel filled with fluid2 ) and outfolw from the tunnel. After fluid1 reaches end of the tunnel a problem appears. Because there is a "recirculation zone" trying to leave the tunnel , imposed boundary conditions does not allow it to leave the computational domain, see attached next 3 figures for different time : recirculation_time_1.jpg recirculation_time_2.jpg recirculation_time_3.jpg I was trying many different BC for velocity (zeroGradient, InletOutlet, mixedDirections) but result/problem is the same... Does any one know if there is some simple (or any using proper BC) solution for this problem ? To just allow fluid to leave domain, without doing mass at the outflow ?? Best |
boundary condition, multiphase flow, outflow |
Complex problem: Open Channel Flow | lett | FLUENT | 18 | November 10, 2018 18:30 |
Fixed Flow rate and outlet Continuity Problem | mrshb4 | OpenFOAM | 1 | March 10, 2012 14:32 |
transient, impregnating flow problem | fgommer | FLUENT | 0 | February 29, 2012 16:10 |
Flow not moving - Supersonic/Initial Pressure problem? | shankara.2 | FLUENT | 0 | June 9, 2009 20:49 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
